BNF Tech Inc.
Post
by BNF Tech Inc. » Mon Jun 25, 2012 10:46 am
I am creating pie chart with marks tio tool,but I found a problem.
Marks tip display only first data only any where in graph. It not display correct data.
Please see the attached screenshot.
Steema.TeeChart.Styles.Pie pie = new Steema.TeeChart.Styles.Pie();
Steema.TeeChart.Tools.MarksTip markstip = new Steema.TeeChart.Tools.MarksTip();
markstip.Style = Steema.TeeChart.Styles.MarksStyles.LabelValue;
tChart1.Tools.Add(markstip);
pie.FillSampleValues(3);
tChart1.Series.Add(pie);
can you please help me? how I display correct data in markstip?
Namit Shah
- you can see it display wrong markstip(i.e. cars 784) on tables.
- pie-markstip.png (45.64 KiB) Viewed 5755 times
Post
by Sandra » Tue Jun 26, 2012 2:25 pm
Hello Namith,
I am afraid that your problem doesn't occur for me using last version of TeeChartFor.Net. I recommend you download last evalutation version and check if your still appears. You can download it
here.
BNF Tech Inc.
Post
by BNF Tech Inc. » Thu Jun 28, 2012 5:55 am
Hi Sandra,
I downloaded new version..still same problem
Please find below Information
version : 4.1.2011.10192
exe name : TeeChartNET2012_4.1.2012.05100.exe
type : X86
os : win7
IDE : Visual studio 2008
I need your help asap to solve this out.
Thanks!
Namit Shah
Post
by Sandra » Thu Jun 28, 2012 10:14 am
Hello Namith,
Sorry, I had checked if your problem occurs with source code and for this reason, the problem doesn't appears for me. Therefore, this problem is solved for next maintenace release of TeeChartFort.Net.
BNF Tech Inc.
Post
by BNF Tech Inc. » Thu Jun 28, 2012 10:40 am
Hi Sandra,
Thanks for your reply
but I do not understand .....that You can not able to reproduce this problem,so problem solved in next relaese
what answer should I give you to my customer??
Its teechart library..which does not support it till next release ...So I am not able to give you that functionality??
If you want reproduce the problem ,If will send .net project solution with problem..Please tell me where I can upload/mail files to you.
Please Give me any other workaround or solution of problem...
once again Thanks !
Namit Shah
Post
by Sandra » Fri Jun 29, 2012 7:49 am
Hello Namit,
Ok, I explain you. Always, I make first the test to find the problems using our source code and after I check it with TeeChart.dll of installer. In your case,I only have checked your problem using our source code and in it doesn't appear the problem, but I have realized that I hadn't made the test with TeeChart.dll, and when I have checked the problem with assembly, it appears. Therefore, yes I can reproduce your problem but it is solved for next maintenace release. I recommend you to be aware at this forum, our
RSS news feed,
twitter and
facebook accounts for new release announcements and what's implemented on them.
