Manually setting of X axis min/max value failed
Re: Manually setting of X axis min/max value failed
and here are 2 screenshots that shows my version info
- download_area.png (27.02 KiB) Viewed 5435 times
- local_version.png (49.92 KiB) Viewed 5424 times
Hi Thomas,
Thanks for the info. There's any other TeeChart.WPF.dll at bin\Debug or bin\Release folders? Can you please check that your project references this very same assembly? If the problem persists could you please send us the TeeChart.WPF.dll assembly you are using so that we can check it here? Please send it at http://www.steema.net/upload/.
Hi Narcis,
you're right. The test app has pointed to the v4 eval version of teechart.wpf.dll. Now I use the dll version 3.5.3700.30575...unfortunately I can't reproduce the problem. My real software project does not working. Now I'm confused.
Nevertheless I sent you the dll version I use. Hope that you can reproduce the problem...
Thanks in advance
Thomas
Thanks in advance
Thomas
Hi Thomas,
Maybe your real project is using the wrong assembly as well or has some code difference which causes this.you're right. The test app has pointed to the v4 eval version of teechart.wpf.dll. Now I use the dll version 3.5.3700.30575...unfortunately I can't reproduce the problem. My real software project does not working. Now I'm confused.
Thanks, this also works fine for me here.Nevertheless I sent you the dll version I use. Hope that you can reproduce the problem.
