Gantt chart: add a label on a connecting pen
gcoray
Post by gcoray » Tue Oct 25, 2011 10:21 am
I have a Gantt serie with some bars. I want to display a line between each bar which will have a label associated.
Example with the picture below:
Label on lines example
The two blocks REQA and ATQA are connected (using the NextTasks property) and a line is displayed between them (using the ConnectingPen property).
Is there a way to add a label on this line, like for the blocks ?
Best regards.
Re: Gantt chart: add a label on a connecting pen
Post by Yeray » Tue Oct 25, 2011 2:38 pm
I'm afraid this is not possible right now. However, it wouldn't be very difficult, for example, to have an array of Annotation tools to show the desired texts.
Post by Narcís » Tue Oct 25, 2011 2:54 pm
Hi gcoray,
Yes, you can do that using Annotation tools set to a custom position in the OnAfterDraw event as in the example here:
    private Steema.TeeChart.Styles.Gantt gantt1;
      gantt1 = new Steema.TeeChart.Styles.Gantt(tChart1.Chart);
      gantt1.Add(DateTime.Now, DateTime.Now.AddDays(2), 1, "task1");
      gantt1.NextTasks[0]=gantt1.Add(DateTime.Now.AddDays(4), DateTime.Now.AddDays(5), 1, "task2");
      tChart1.Draw();
      for (int i = 0; i < gantt1.NextTasks.Count; i++)
        int next = (int)gantt1.NextTasks[i];
        if (next != -1)
          Steema.TeeChart.Tools.Annotation annotation1 = new Steema.TeeChart.Tools.Annotation(tChart1.Chart);
          annotation1.Shape.CustomPosition = true;
          annotation1.Text = "Connecting line " + i.ToString();
          SizeF textSize = g.MeasureString(annotation1.Shape.Font, annotation1.Text);
          int x = gantt1.CalcXPosValue(gantt1.EndValues[i]) + (gantt1.CalcXPosValue(gantt1.StartValues[next]) - gantt1.CalcXPosValue(gantt1.EndValues[i])) / 2;
          int y = gantt1.CalcYPos(i) - 30;
          annotation1.Shape.Left = x - (int)textSize.Width / 2;
          annotation1.Shape.Top = y;
gcoray
Post by gcoray » Tue Oct 25, 2011 3:43 pm
Thank you very much ! I think this will be fine.
Best regards.
