Hello
I searched in the demo project, but coudn't find how to show two different axis on the right side of the tChart.
I have three series on my chart. One (type Bar) has as vertical Axis the tChart.Axes.Left, and the otherones (type Line) have as vertical Axis the tChart.Axis.Right.
But the two series on tChart.Axis.Right don't have the same range.
How can I add an additional Axis to the tChart (on the right side) with a new range and add one series to this new axis?
To show the two different values (legend) of the two axises, one could show the values on the left of the Axis (inside the chart) and the other on the right of the chart (outside the chart). Both could also be shown outside the tChart (on the right side of the axis)
I'm very thanksfull for a solution.
Eric
Two different Axis on the right side of the Chart
Re: Two different Axis on the right side of the Chart
Hello Eric,
I suggest you take a look, in example demo All Features\Welcome !\Axes\Permanent custom axes, where you can see as you do to add a custom axes in the right Axis. If you have any problems with it, please let me know.
Hola Sandra
I added a custom axis, thanks for your advice. If have two more questions:
Is there a way, that I can show the orange Labels inside the Chart?
At the moment I moved the labels to the right by setting the axis1.Ticks.Length to 35. How can I make moving to the left into the chart? (see attchement)
When I make the cusom axis1 visible, the Tchart1 dosn't automaticly become smaller to show the full lables (like it does with tChart1.Axes.Right). As you see on the pictures (see attchement), the orange lables from the axis1 are cut off a little bit.
- Picture.JPG (85.35 KiB) Viewed 8156 times
Additional information:
When I make the tChart1.Axes.Right.Visible = false (the violett axis), the chart resizes automaticly and becomes bigger and the the orange (the custom axis) is outside the picture
Hola
I found the solution:
with Axis.Positon.Position = xx% I can the position of the axis to any point
And because I have the labels inside the chart now (at 100%, but "Other side" not selected) I don't have the problem any more, that the labels are outside the tChart image. !!
Hasta luego
Eric
Hasta luego
Eric
Hello Eric,
I am glad that you found a solution for your problem.
Gracias,
Gracias,
