antoine
Post
by antoine » Thu Aug 04, 2011 9:20 am
Just to let you know that I found an issue with the Label axes:
- axes lebel issue
- AxesLabel.PNG (19.41 KiB) Viewed 6374 times
the axes is configure like this:
in_TChart.Axes.Left.Minimum = 49;
in_TChart.Axes.Left.Maximum = 50;
in_TChart.Axes.Left.Increment = 0,1;
in_TChart.Axes.Left.Labels.Exponent = true;
in_TChart.Axes.Left.Labels.ValueFormat = "#.0 x10 E+0";
If the ValueFormat is set to "#.00 x10 E+0", the label is well displayed.
Post
by Sandra » Thu Aug 04, 2011 1:08 pm
Hello Antonie,
I couldn't reproduce your problem using next code:
line1 = new Steema.TeeChart.Styles.Line(tChart1.Chart);
line1.Add(1.0);
line1.Add(1.0e+1);
line1.Add(1.0e+2);
line1.Add(1.0e+2);
line1.Add(1.0e+2);
line1.Add(1.0e+2);
line1.Add(1.0e+2);
tChart1.Axes.Left.Minimum = 49;
tChart1.Axes.Left.Maximum = 50;
tChart1.Axes.Left.Increment = 0.1;
tChart1.Axes.Left.Labels.Exponent = true;
tChart1.Axes.Left.Labels.ValueFormat = "#.0 x10 E+0";
Can you please, tell us, if in previous code appears your problem? Moreover, if in code you can reproduce your problem, please explain how we can reproduce it here.
antoine
Post
by antoine » Thu Aug 04, 2011 1:22 pm
I am using the WPF version of TChart.
Post
by Sandra » Thu Aug 04, 2011 2:20 pm
Hello antonie,
Sorry, you are right and it occurs in WinForms too. I have added your request in the bug list report with number [TF02015683]. We will try to fix it for next versions of Teechart.Net
antoine
Post
by antoine » Thu Aug 04, 2011 2:22 pm
I have been able to reproduce it.
I enclosed the small I made to test it.
- TestLine TChart.rar
- (34.83 KiB) Downloaded 348 times
Post
by Sandra » Fri Aug 05, 2011 9:57 am
Hello antoine,
Thank you for your project, it will be helpful to solve the problem. I recommend you to be aware at this forum, our
RSS news feed,
twitter and
facebook accounts for new release announcements and what's implemented on them.
Post
by Yeray » Fri Aug 05, 2011 10:25 am
Hello antonie,
I've looked at this and I think it's more a .NET Framework issue than a TeeChart related one. Note that TeeChart uses the Framework functions to format the values to get the strings. The problem is actually reproducible without any chart, simply with the following code:
double tmp = 4.95e+1;
this.Text = tmp.ToString("#.0 x10 E+0") + " " + tmp.ToString("#.00 x10 E+0");
