I need to make a time graph like the attached image but in vertical direction.
I need that in the left axe shows the time and the bottom axe shows a progressive number
And it could be better if is a line graph.
How can I do that?
Thanks!
Time Chart
Time Chart
- Dibujo1.JPG (48.63 KiB) Viewed 4132 times
Re: Time Chart
Hello ternaris,
I have made a simple example, where Y values are DateTime using method ToOADate() and I think next code help you to achieve as you want:
Could you please, tell us if previous code works fine to you?
Steema.TeeChart.Styles.HorizBar horizBar = new Steema.TeeChart.Styles.HorizBar(tChart1.Chart);
horizBar.YValues.DateTime = true;
DateTime today = DateTime.Today;
TimeSpan oneDay = TimeSpan.FromDays(1);
for (int i = 1; i < 10; i++)
horizBar.Add(i,today.ToOADate(),Color.Green);
today += oneDay;
