TChart1.Walls.Visible and Position Offset %
Maverick123
Post by Maverick123 » Tue Jul 05, 2011 9:54 am
I am switching from TeeChart Pro v7.0.0.7 to TeeChart .Net Pro v.4.0.2011.2082.
This time I have two questions:
Question.01.
I want to clear every thing I set on graph by using following code
TChart1.Series.Clear()
TChart1.Axes.Left.Title.Caption = ""
TChart1.Axes.Bottom.Title.Caption = ""
TChart1.Header.Text = ""
TChart1.Axes.Left.Visible = False
TChart1.Axes.Bottom.Visible = False
TChart1.Walls.Visible = False
In a result Right and Top of Wall do not disappear. It seems that walls visible property works for left and bottom side but not for right and top side or some thing like this. For better understanding I am attaching a document having print shots, before and after executing above code. Here I want to mention that Walls.Visible property worked fine in TeeChart7.
Question.02.
How can I access/alter following property on run time
TeeChartEditor-->Legend-->Position-->Position Offset %.
Hope you understand above hierarchy , I provide print shot of exact screen as well.
Maverick
Two Questions.zip
Doc. file having print shots for better understanding of problem.
(62.04 KiB) Downloaded 324 times
Re: TChart1.Walls.Visible and Position Offset %
Post by Sandra » Tue Jul 05, 2011 3:15 pm
Hello Maverick,
You need know that Walls Right, for default isn't visible, so property Walls work fine as you can see i next image, where I have changed the color of Chart Panel and I have set the walls as not visible:
Image Walls.Visible=true:
Image Walls.Visible=false:
To genereted this image I have use next code:
Private ChartController1 As Steema.TeeChart.ChartController
Public Sub New()
	InitializeComponent()
	tChart1.Aspect.View3D = False
	InitializeChart()
Private Sub InitializeChart()
	Dim points As New Steema.TeeChart.Styles.Points(tChart1.Chart)
	ChartController1 = New Steema.TeeChart.ChartController()
	Me.Controls.Add(ChartController1)
	ChartController1.Chart = tChart1
	points.FillSampleValues()
	tChart1.Panel.Gradient.Visible = False
	tChart1.Panel.Color = Color.Green
Private Sub button1_Click(sender As Object, e As EventArgs)
	Dim line As New Steema.TeeChart.Styles.Line(tChart1.Chart)
	line.FillSampleValues()
	line.HorizAxis = Steema.TeeChart.Styles.HorizontalAxis.Top
	line.VertAxis = Steema.TeeChart.Styles.VerticalAxis.Right
Private Sub button2_Click(sender As Object, e As EventArgs)
	tChart1.Series.Clear()
	tChart1.Axes.Left.Visible = False
	tChart1.Axes.Bottom.Visible = False
	tChart1.Walls.Visible = False
Please check previous code if works as you expected? If isn't work as you want please explain exactly why you think that walls are visible so we can try to help you to solve it.
Question.02.
If you want change Position Offset% of legend to run time you need change value of property TopLeftPos as do in following line of code:
 tChart1.Legend.TopLeftPos=40
Maverick123
Post by Maverick123 » Wed Jul 06, 2011 6:53 am
Sandra,
Thanks for your effort.
I have attached another document to elaborate, what exactly I demand for.
Hope it will work.
Ques1.zip
Another doc. for better understanding of problem
(39.09 KiB) Downloaded 348 times
Post by Sandra » Wed Jul 06, 2011 7:44 am
Hello Maverick,
If you can need set axes property visible = false as do in following line of code:
    tChart1.Axes.Visible = false;
Can you tell us if previous line of code works as you want?
Maverick123
Post by Maverick123 » Thu Jul 07, 2011 5:54 am
Sandra,
Bundle of Thanks.
Hmmm...Yes it works and it means the right and top lines left, are part of Axis not walls.
I am facing another problem.
I am switching from TeeChart Pro v7.0.0.7 to TeeChart .Net Pro v.4.0.2011.2082. So all code written for TeeChart7 is required to change according to TeeChart.Net . Following piece of code written for TeeChart7 doesn't seem to work in sample project according to my understanding.
There are 8 points in the Series(0).
For i  = 1 To 8
      TChart7.Series(0).PointColor(i) = TeeChart.EConstants.clTeeColor
Next
As per my understanding above piece of code should change the color of all 8 points of series. But color is not changed at all after executing it.
Question A.
Please tell me "PointColor" in TeeChart7 was working fine? or i am doing something wrong? OR it depends upon any other property?
Question B.
What is alternate of "PointColor" in TeeChart.Net?
Please consider that i need to use it in a LOOP so
TChart1.Series(0).Color = Color.Pink
will not work as an alternate in TeeChart.Net for me.
Hope you will not mind my new questions in reply of pervious questions.
Maverick.
Post by Sandra » Thu Jul 07, 2011 9:41 am
Hello Maverick,
Question A.
About description of PointColor The Series PointColor property is an array of TColor values. Each color value corresponds to a different point in the Series. So, you have understood well the behavior of PointColor and you need know that i TeeChart Activex v7 and v8 it don't works properly but is solved in last Activex 2010, where PointColor works fine.
Question B. What is alternate of "PointColor" in TeeChart.Net?
In TeeChart.Net if you want achieve the same behavior of property PointColor you only need change for each point its color, as do in following lines:
 for(int i=0; i<8; i++)
                tChart1[0][i].Color = Color.Red;
Do not worry I do not care :). But,I suggest you, in future try to do the questions in different threats, so is easier do a tracking for us and the other users, if the different questions are in different threads.
Maverick123
Post by Maverick123 » Thu Jul 07, 2011 10:41 am
Sandra,
Thanks a lot,
The alternate(.Net) of "PointSeries"(ActiveX) is working fine. I must say its realy hard to find it without your support.
I am asking different questions in reply of your answers because in this way i got answers more quickly as compared to the questions asked in different threat. :)
Anyhow i have another question but i will ask in different threat as per your suggestion.
Maverick
