How to disable options of ChartController on run time?
Maverick123
Post by Maverick123 » Wed Jun 29, 2011 9:18 am
I am switching from TeeChart Pro v7.0.0.7 to TeeChart .Net Pro v.4.0.2011.2082. I want to disable some options provided by “ChartController”. e.g. “Add”, “Delete”, “Title”, “Clone” and “Change” buttons for series tab on run time (through code). In TeeChart7 I was doing the same by using Editor using following code
TeeCommander1.EditorLink = TeeEditor1.EditorLink
TeeEditor1.Options.Add = False
How I can perform same functionality in TeeChart for .Net 2010?
Thanks and Regards,
Immi
Re: How to disable options of ChartController on run time?
Post by Sandra » Thu Jun 30, 2011 1:14 pm
Hello Maverick123,
I recommend you, take a look in demo project, concretely in All Features\Welcome!\Components\ChartController\ChartController Editor where you can see how you can customizing your ChartController.
Maverick123
Post by Maverick123 » Fri Jul 01, 2011 6:48 am
Sandra,
Thanks for reply,
In Demo project i got the way to hide whole tab(s). Even if i can hide buttons through "ChartEditorOptions" it will not solve my problem because i want to Disable buttons (not hide) as were done in TeeChart7.
I am repeating my question: How can I disable “Add”, “Delete”, “Title” etc buttons on series tab of ChartController in TeeChart for .Net 2010? I will appreciate of you can provide me a sample code for this.
Maverick
Post by Narcís » Fri Jul 01, 2011 10:04 am
Hi Maverick,
You need to do as Yeray explained here. So that in your case would be:
      Steema.TeeChart.Editor editor = new Steema.TeeChart.Editor(tChart1);
      Steema.TeeChart.Editors.ChartEditorOptions[] options = new Steema.TeeChart.Editors.ChartEditorOptions[2] {
                                                              Steema.TeeChart.Editors.ChartEditorOptions.Clone,
                                                              Steema.TeeChart.Editors.ChartEditorOptions.Change };
      editor.Options = options;
      editor.ShowModal();
Maverick123
Post by Maverick123 » Fri Jul 01, 2011 12:25 pm
Hello Narcis,
Thanks a lot for your reply,
I think you are not getting my point although i tried to explain clearly in my last reply. i.e.
The code you provided is hiding the buttons/options not disabling.
In order to explain more clearly i am attaching a document having print shots of, what i am looking for and what sample code is doing.
Hope it works,
I have another question. In TeeChart7 i copied the graph into clipboard by using following code
TChart1.Export.CopyToClipboardMetafile(True)
What is the alternate of "CopyToClipboardMetafile" in .Net version of TeeChart. OR How i can achieve the previous functionlaity in through .Net version of TeeChart.
Hope you will not mind my 2nd question in reply of the first one :)
Maverick
TeeChart.zip
Doc file explaining my problem.
(35.01 KiB) Downloaded 317 times
Post by Narcís » Fri Jul 01, 2011 1:01 pm
Hi Maverick,
Sorry, I see what you mean now. I'm afraid this is not possible, only toggling them is possible for now. I'll add your request to the wish-list to be considered for inclusion in future releases (TF02015635).
There's an example of this at All Features\Welcome !\Exporting\Chart Picture\Metafile example in the features demo available at TeeChart's program group.
