Series getting overlapped with another series on chart
VarUser
Post by VarUser » Wed Jun 22, 2011 9:32 am
We are displaying multiple series on chart and the series have custom axis. PFA herewith the snapshot of problem we are describing.
The problem is that when you scroll the data in one of the series, the series data gets drawn in the area of another series. Actually if series data goes out of series range it should not display anything.
Below is the sample code depicting the problem.
- JC
private const byte AlphaChanel = 64;
private void Window_Loaded(object sender, RoutedEventArgs e)
tChart.Aspect.View3D = false;
tChart.Aspect.Orthogonal = false;
//ltangL UseGuildLines improves performance but creating drawing gaps (TeeChart bug?)
//tChart.Aspect.UseGuidelines = true;
tChart.ClipToBounds = true;
tChart.Aspect.ClipPoints = true;
//tChart.Axes.Left.Grid.Visible = false;
//tChart.Axes.Bottom.Grid.Visible = false;
//tChart.Axes.Bottom.MaximumOffset = 8;
//tChart.Axes.Bottom.MinimumOffset = 8;
//ltang: Insert gap between bottom axis and series
//tChart.Axes.Left.MaximumOffset = 8;
//tChart.Axes.Left.MinimumOffset = 8;
//ltang: Make rooms for displaying axes' labels
tChart.Panel.MarginUnits = PanelMarginUnits.Pixels;
tChart.Panel.MarginLeft = 45;
tChart.Panel.MarginBottom = 30;
tChart.Panel.MarginRight = 45;
tChart.Panel.MarginTop = 5;
Color color = Colors.White;
color.A = AlphaChanel;
tChart.Panel.Color = color;
tChart.Panel.Shadow.Visible = false;
tChart.Walls.Back.Color = color;
tChart.Panel.Bevel.ColorOne = Colors.Transparent;
tChart.Panel.Bevel.ColorTwo = Colors.Transparent;
tChart.Panel.Gradient = null;
tChart.Walls.Visible = false;
tChart.Legend.Visible = false;
tChart.Header.Font.Size = 16;
//tChart.Zoom.Direction = ZoomDirections.Horizontal;
//tChart.Zoom.Allow = true;
tChart.Panning.MouseButton = MouseButton.Left;
FastLine series1 = AddSeries(1);
FastLine series2 = AddSeries(2);
series1.Cursor = Cursors.Hand;
series1.GetVertAxis.StartPosition = 0;
series1.GetVertAxis.EndPosition = 50;
series1.GetVertAxis.Visible = true;
//series1.GetHorizAxis.Visible = false;
series2.GetVertAxis.StartPosition = 61;
series2.GetVertAxis.EndPosition = 100;
series2.GetVertAxis.Visible = true;
series2.GetHorizAxis.Visible = true;
tChart.Zoom.Direction = ZoomDirections.Both;
//tChart.Zoom.Animated = true;
tChart.Zoom.History = true;
//tChart.Series.Add(series);
//SeriesMarks marks = new SeriesMarks(series2);
//marks.Clip = true;
//marks.Transparent = true;
AxisScroll scrollTool1 = new AxisScroll(series1.GetHorizAxis);
AxisScroll scrollTool2 = new AxisScroll(series2.GetHorizAxis);
AxisScroll scrollTool3 = new AxisScroll(series1.GetVertAxis);
AxisScroll scrollTool4 = new AxisScroll(series2.GetVertAxis);
//tChart.Zoomed += new EventHandler(tChart_Zoomed);
private FastLine AddSeries(int i)
FastLine series = new FastLine(tChart.Chart);
series.Add(new Point(1, 10 * i));
series.Add(new Point(2, -10 * i));
series.Add(new Point(3, 20 * i));
series.Add(new Point(4, 40 * i));
series.Add(new Point(5, 40 * i));
series.Add(new Point(6, 10 * i));
//series.CustomVertAxis = new Axis(tChart.Chart);
//series.GetVertAxis = series.CustomVertAxis;
Axis xAxis, yAxis;
xAxis = (Axis)tChart.Axes.Bottom.Clone();
yAxis = (Axis)tChart.Axes.Left.Clone();
series.CustomHorizAxis = xAxis;
series.CustomVertAxis = yAxis;
tChart.Axes.Custom.Add(xAxis);
tChart.Axes.Custom.Add(yAxis);
xAxis.Automatic = false;
yAxis.Automatic = false;
xAxis.Minimum = 1;
xAxis.Maximum = 7;
yAxis.Minimum = -40;
yAxis.Maximum = 60;
//xAxis.Minimum = xAxis.Maximum = 0;
xAxis.Visible = false;
yAxis.Visible = false;
return series;
showing overlapped series problem
Re: Series getting overlapped with another series on chart
Post by Sandra » Thu Jun 23, 2011 9:48 am
Hello VarUser,
I recommend that you take a look in the Demo project concretely in the All Features\Welcome !\Axes\Opaque zones where works with custom axes and doesn't allow that series are drawn in the area of another series.
