Gauge Logarithmic Axis WPF
antoine
Post by antoine » Tue Jun 21, 2011 9:42 am
I would like to use a logarithmic axis on a gauge but I don't know how to do it.
I have the following code:
Gauges gauge = new Gauges();
gauge.TotalAngle = 270;
gauge.RotationAngle = 225;
Steema.TeeChart.WPF.Axis logAxis = tc_Chart.Axes.Right;
logAxis.Logarithmic = true;
logAxis.LogarithmicBase = 10;
logAxis.SetMinMax(0, 10000);
this.tc_Chart.Series.Clear();
tc_Chart.Series.Add(gauge);
tc_Chart[0].FillSampleValues();
tc_Chart.Axes.Right.Logarithmic = true;
tc_Chart.Axes.Right.LogarithmicBase =10;
tc_Chart.Axes.Left.Logarithmic = true;
tc_Chart.Axes.Left.LogarithmicBase = 10;
this.displayType = en_DisplayType.gauge;
this.tc_Chart.Axes[1].Logarithmic = true;
I am using the WPF version of Teechart.
Could you help me please?
antoine
Re: Gauge Logarithmic Axis WPF
Post by antoine » Tue Jun 21, 2011 2:38 pm
I have tried to use the logarithmic axis with a Winform Gauge but it gave me the same result.
Post by Sandra » Wed Jun 22, 2011 10:19 am
Hello antoine,
I have made a simple code but I am not sure if this is as you want:
        private void InitializeForm()
            Steema.TeeChart.WPF.Styles.Gauges gauge = new Steema.TeeChart.WPF.Styles.Gauges();
            tChart1.Series.Clear();
            tChart1.Series.Add(gauge);
            tChart1[0].FillSampleValues();
            gauge.Minimum = 0;
            gauge.Maximum = 10000;
            tChart1.Axes.Left.Increment = 1000;
            tChart1.Axes.Left.Logarithmic = true;
            tChart1.Axes.Left.LogarithmicBase = 10;
Can you tell us if previous code works as you want? And also please can you explain exactly what do you want achieve using in gauge a logarithmic scale, we can try to help you to find the best solution for you?
antoine
Post by antoine » Thu Jun 23, 2011 9:47 am
Thanks, that's what I wanted.
Now I have the following code:
 CircularGauge gauge = new CircularGauge();
//Gauges gauge = new Gauges();
gauge.TotalAngle = 220;
gauge.RotationAngle = 0;
gauge.DisplayRotationAngle = 0;
//display the numeric value
gauge.NumericGauge.Visible = true;
gauge.FaceBrush.Color = (Color)this.FindResource("CSPMS_Color_BackDark");
gauge.FaceBrush.Gradient.Visible = false;
gauge.Minimum = 0.1;
gauge.Maximum = 1000;
tc_Chart.Axes.Left.Increment = 10;
If the Increment property is to small, the label on the axis can't be read. Is it possible to autosize the label?
Is it a semi-log or a log? What I mean by semi-log is that the axis is linear decade.
When I use this:
((CircularGauge)tc_Chart.Series[0]).Value = rand.Next(10000);
If the random number is superior the max value of the gauge(1000), the gauge does not resize.
Regards.
Post by Sandra » Thu Jun 23, 2011 12:22 pm
Hello antoine,
You can try to use property separation of axes labels to separate the labels. And also I recommend you to read this thread where almost all possibilities about overlapping labels where discussed and as left axis is the axis that Gauges/CircularGauge series use so those are the labels you should work with.
I have checked it and your are right. I have added it in wish-list with number [TF02015626] to be consider inclusion in next maintenance releases of TeeChart.Net.
When I use this:
Using this code and last version of TeeChart.Net WPF the gauge resize for me.
 Random rnd;
            rnd = new Random();
            Steema.TeeChart.WPF.Styles.CircularGauge gauge = new Steema.TeeChart.WPF.Styles.CircularGauge();
            tChart1.Invalidate();
            gauge.Minimum = 0;
            gauge.Value = rnd.Next(10000);
            tChart1.Axes.Left.Increment = 100;
            rnd = new Random();
            (tChart1[0] as Steema.TeeChart.WPF.Styles.CircularGauge).Value = rnd.Next(10000);
Could you please, check if previous code works for you? On the other hand, you can tell us which version of TeeChart are you using, now?
antoine
Post by antoine » Thu Jun 23, 2011 2:40 pm
Hi Sandra,
I am using the 4.1.2011.4193 version of teechart.
I'm using the WPF component.
I have tried to display the NumericGauge in the CircularGauge but nothing is displayed in it as you can see on the image below:
I have set the AutoValueNumericGauge attribut to true.
I took the exemple from "Welcome !\Chart styles\Gauges\Numeric Gauge".
Another point: I did not manage to change the color of the RedLine and GreenLine, only the border (as you can see on the picture).
gauge.AutoValueNumericGauge = true;
gauge.FaceBrush.Color = (Color)this.FindResource("CSPMS_Color_BackDark"); //color from a xaml file
gauge.Minimum = 0;
//alarm level
gauge.RedLineStartValue = Double.Parse(device.CSPProbe.channel1.alarm);  //800
gauge.RedLineEndValue = gauge.Maximum;
gauge.RedLine.Pen.Color = (Color)this.FindResource("CSPMS_color_alarmBright");
//alert level
gauge.GreenLineStartValue = Double.Parse(device.CSPProbe.channel1.alert); //500
gauge.GreenLineEndValue = Double.Parse(device.CSPProbe.channel1.alarm); //800
gauge.GreenLine.Pen.Color = (Color)this.FindResource("CSPMS_color_alertBright");
tc_Chart.Axes.Left.Increment = 100;
antoine
Post by antoine » Thu Jun 23, 2011 2:45 pm
Oh, and has you can see, the axis is not Logarithmic.
In the timer_tick, i'm using this to update the value:
Random rand = new Random();
            if (tc_Chart.Series[0].GetType() == typeof(CircularGauge))
                ((CircularGauge)tc_Chart.Series[0]).Value = rand.Next(1000);
                tc_Chart.Invalidate();
Post by Sandra » Mon Jun 27, 2011 9:54 am
Hello antonie,
You are right. I have checked your request and I have added it in bug list report with number [TW16015628]. We will try to fix it for next maintenance releases of TeeChart.Net.
If you want change color of the RedLine and GreenLine you need disable gradient of both as do in next code:
Private void InitializeChart()
            Steema.TeeChart.WPF.Styles.CircularGauge Cgauge = new Steema.TeeChart.WPF.Styles.CircularGauge(tChart1.Chart);
            Cgauge.GreenLine.Gradient.Visible = false;
            Cgauge.GreenLine.Brush.Color = Colors.Blue;
            Cgauge.GreenLine.Pen.Color = Colors.Red;
            Cgauge.RedLine.Gradient.Visible = false;
            Cgauge.RedLine.Brush.Color = Colors.Yellow;
            Cgauge.RedLine.Pen.Color = Colors.GreenYellow;
Could you tell us if previous code works as you want?
How I have told in previous post this behavior is in wish list with number(TF02015626) to be considered its inclusion for next versions of TeeChart.Net WPF. On the other hand, the value is updated well for me so you can try to arrange for us a simple project because we can reproduce exactly your problem here?
antoine
Post by antoine » Tue Jun 28, 2011 8:15 am
Hi Sandra,
I enclosed a test project with a simple CircularGauge with the NumericGauge wich does not update.
It seems that the NumericGauge does not work at all (even without the CircularGauge) in WPF.
The code you provide me to change the color of the RedLine and GreenLine works great.
Antoine.
TestGauge.rar
(31.24 KiB) Downloaded 413 times
Post by Sandra » Tue Jun 28, 2011 3:17 pm
Hello antoine,
Thank you for your project. I have added your information in the bug (TW16015628).
antoine
Post by antoine » Tue Aug 02, 2011 6:41 am
Hi Sandra,
I am have some difficulties to deal with the Axis of my gauge.
Has you can see on the picture, the labels on the Axis are all "0". At the bottom left you have the current value of the gauge.
gauge
I am using the following code to display the axis:
gauge.Minimum = 0;
gauge.Maximum = 1e-9;
Steema.TeeChart.WPF.Axis leftAxis = in_TChart.Axes.Left;
leftAxis.Automatic = true;
leftAxis.AutomaticMaximum = true;
leftAxis.Increment = gauge.Maximum / 10;
leftAxis.Labels.ValueFormat = "#.#E+0";
in_TChart.Series.Clear();
in_TChart.Series.Add(gauge);
Thank you for your help,
Antoine.
Post by Sandra » Tue Aug 02, 2011 9:25 am
Hello antoine,
I think that your problem is, that you doesn't change the correct ValueFormat, so you are changing ValueFormat of labels of Axis and you need change ValueFormat of Value of gauge, as do in next example:
        Steema.TeeChart.WPF.TChart tChart1;
            tChart1 = new Steema.TeeChart.WPF.TChart();
            this.Content = tChart1;
            CircularGauge gauge = new CircularGauge(tChart1.Chart);
            gauge.Minimum = 0;
            gauge.Axis.Automatic = false;
            gauge.Axis.Increment = gauge.Maximum / 10;
            gauge.ValueFormat = "#.0x10E+0";
Could you confirm us if previous code works as you expected?
antoine
Post by antoine » Tue Aug 02, 2011 9:50 am
Thanks, it works!
