Series.Add<T>?
John
Series.Add<T>?
Post by John » Mon May 16, 2011 5:10 pm
Is there an example on the use of series.Add<t>?
If I define a list<xypoint> can I use this in a line series?
class xypoint
double x;
double y;
Re: Series.Add<T>?
Post by Yeray » Tue May 17, 2011 4:10 pm
Hello John,
The "Add<T>(T TType)" method is intended for those who have an unknown type of source. The method calls the according Add override for the given parameter type. For example if you have a list of object but for any reason you don't know if the list is a list of integers or doubles or ... the "Add<T>(T TType)" method will call "Add(Convert.ToInt32(TType))" or "Add(Convert.ToSingle(TType))" or ...
In your case, I think you are sure you'll have doubles, isn't it? In that case you could directly use the "Add(PointF p)" or the "Add(double x, double y)"
jdsu
Re: Series.Add<T>?
Post by jdsu » Wed Jun 15, 2011 8:31 am
I am facing an issue in which the Series.Add<T> doesn't work with the UInt64 type. Can you help me confirm this and how I can get over this issue?
Best regards,
Siguo
Re: Series.Add<T>?
Post by Narcís » Thu Jun 16, 2011 9:41 am
Hi Siguo,
I'm afraid Series.Add<T> doesn't support UInt64 at the present moment. I have added your request (TF02015619) to the wish-list to be considered for inclusion in future releases. In the meantime you should convert UInt64 manually as Yeray indicated.
