Setting width of the Axis
Markus
Post by Markus » Fri May 20, 2011 4:09 pm
In my window I have two Tcharts next to each other (Top and Bottom). However the range of the Y Axis is different for the two. Y Axis range for one is: -20 to -110 and for another: 10 to -50. Since the max value for one is 3 digits, it takes more space then the another one, thus the two charts are not aligned. (See the attached image)
Is there a way I can set the width of the Axis labels, so that the two charts are aligned?
Re: Setting width of the Axis
Post by Sandra » Mon May 23, 2011 10:30 am
Hello Markus,
I recommend take a look in next link where you can find a solution to set correctly max label width.
Markus
Post by Markus » Tue May 24, 2011 8:38 pm
The Link that you provide works fine. Thanks.
