CKBN
Post
by CKBN » Thu May 12, 2011 2:17 pm
What will make NearestPoint.Point equals -1?
In my
Steema.TeeChart.Tools.NearestPoint Change
event handler most of my series works perfect, but for some series NearestPoint.Point always = -1
Also NearestPoint.GetNearestPoint(cursorPosition); returns -1.
My event handler look like this:
private Steema.TeeChart.Tools.NearestPoint tNearestPoint;
private EventHandler _steemaTeeChartToolsNearestPointEventHandler = null;
_steemaTeeChartToolsNearestPointEventHandler = new EventHandler(tNearestPoint_Change);
tNearestPoint.Change += _steemaTeeChartToolsNearestPointEventHandler;
private void tNearestPoint_Change(object sender, EventArgs e)
try
if (NearestPointChangeDelegate != null)
if (tNearestPoint.Point != -1)
NearestPointChangeEventArgs nearestPointChangeEventArgs = new NearestPointChangeEventArgs(
tNearestPoint.Series.XValues[tNearestPoint.Point],
tNearestPoint.Series.YValues[tNearestPoint.Point]);
NearestPointChangeDelegate(this, nearestPointChangeEventArgs);
Point cursorPosition = ((System.Windows.Forms.Control)Chart).PointToClient(System.Windows.Forms.Cursor.Position);
int point = tNearestPoint.GetNearestPoint(cursorPosition); //Also always = -1;
catch (Exception ex)
Ellab.Debug.GlobalDebug.debugForm.WriteText(ex);
Thanks a lot in advance
Christian
Post
by Sandra » Fri May 13, 2011 10:10 am
Hello Christian,
I couldn't reproduce your problem using next code:
Steema.TeeChart.Styles.Points point,point1;
Steema.TeeChart.Tools.NearestPoint nearest1;
point = new Steema.TeeChart.Styles.Points(tChart1.Chart);
point1 = new Steema.TeeChart.Styles.Points(tChart1.Chart);
nearest1 = new Steema.TeeChart.Tools.NearestPoint(tChart1.Chart);
point.FillSampleValues();
nearest1.Series = this.point;
point1.FillSampleValues();
nearest1.Change += new EventHandler(nearest1_Change);
void nearest1_Change(object sender, EventArgs e)
if (nearest1.Point != -1)
this.Text = nearest1.Point.ToString();
Please, could you tell us if you can reproduce your problem using previous code? And if your problem doesn't appears in using previous code please send us a simple project that we can reproduce exactly your problem.
CKBN
Post
by CKBN » Mon May 16, 2011 10:25 am
Hi Sandra,
Sorry for the confusion, but my question is simply:
In what conditions will NearestPoint.GetNearestPoint(...) return -1?
Thanks a lot in advance.
Christian
Post
by Yeray » Tue May 17, 2011 11:03 am
Hello Christian,
CKBN wrote:In what conditions will NearestPoint.GetNearestPoint(...) return -1?
When the series linked to the tool has no points or when the points in the series are out of the axes range.
I don't see any other situation where it could return -1. However, feel free to study the function yourself (you can use RedGate's Reflector to read the TeeChart.dll via reflection if you are not a source code customer).
CKBN
Post
by CKBN » Tue May 17, 2011 11:15 am
Thanks a lot. That gives me some better debug capabilities. I’m sure that the error is in my code.
Also, thanks for the tip about the RedGate's Reflector tool. I’ll definitely give it a try.
BR,
Christian
Post
by Yeray » Tue May 17, 2011 3:37 pm
Hi Christian,
I'm happy to hear that
If you think you find a bug in TeeChart's code, don't hesitate to let us know.
