SVG image from invertet stairs series
FT_GIAG_Old
Post by FT_GIAG_Old » Tue Dec 14, 2010 3:53 pm
Hello
I’ve got a problem generating an SVG image from a chart. It works fine, as long as I haven’t got a series with line mode "stairs" and "inverted". As you can see in the attached SVG file, only the vertical line of the stairs and the curve itself are painted. If I try it with normal "stairs" it's painted correctly.
Thanks for your help
Florian Treier
InvertedStairs.zip
(3.57 KiB) Downloaded 302 times
Re: SVG image from invertet stairs series
Post by Sandra » Wed Dec 15, 2010 4:38 pm
Hello FT_GIAG,
Ok. I could reproduce your problem. I have added your request in bug list report with number [TF02015323]. We will try to fix it, for next maintenance releases of TeeChart.Net.
On the other hand, I suggest you for now, you use a FastLine series as a workaround, so it exports image correctly in format SVG.
FT_GIAG_Old
Post by FT_GIAG_Old » Thu Dec 16, 2010 10:47 am
Hello Sandra
Thanks for your quick reply. It would be great if it were fixed in the next version. Btw, any idea when that's going to be?
About your workaround: what are the differences between Line and FastLine, apart from the obvious that FastLine should be faster?
Florian Treier
Post by Sandra » Thu Dec 16, 2010 12:06 pm
Hello FT_GIAG,
I can't still provide an estimate date. I recommend you to be aware at this forum, our RSS news feed, twitter and facebook accounts for new release announcements and what's implemented on them.
FastLine is similar to a Line but stripped down to the very basics for performance purposes. There it doesn't have some Line series properties or objects like Pointers, for example. You also can take a look in the Help for see all both properties and methods.
FT_GIAG_Old
Post by FT_GIAG_Old » Fri Jun 10, 2011 4:11 pm
Hello Sandra
I finally got some time to try the new TeeChart Version (4.1.2011.04192)... Unfortunately, this bug is now "reversed": It works perfectly for "stairs" and "inverted", but if I just set "stairs", I get an image similar to the one attached to my first post...
Could you look into that?
Florian Treier
Post by Sandra » Tue Jun 14, 2011 4:36 pm
Hello Florian Treier,
I couldn't reproduce your problem using last version of TeeChart.Net and next code:
            Steema.TeeChart.Styles.Line line = new Steema.TeeChart.Styles.Line(tChart1.Chart);
            line.FillSampleValues();
            line.Stairs = true;
            line.InvertedStairs = false;// false;
            tChart1.Draw();
            tChart1.Export.ShowExportDialog();
Please, can you tell us if using previous code you can reproduce your problem? If you don't reproduce your problem with my code, please modify it or send us a simple project, so we can reproduce exactly your problem.
FT_GIAG_Old
Post by FT_GIAG_Old » Wed Jun 15, 2011 10:09 am
Hello Sandra
I could reproduce it with your code...
Still, I edited the code a bit, so I could compare inverted and normal stairs in one diagram
	Line line1 = new Line(tChart1.Chart);
	line1.FillSampleValues();
	line1.Stairs = true;
	line1.InvertedStairs = true;
	line1.Title = "Inverted Stairs";
	line1.Color = Color.Red;
	Line line2 = new Line(tChart1.Chart);
	line2.FillSampleValues();
	line2.Stairs = true;
	line2.InvertedStairs = false;
	line2.Color = Color.Green;
	line2.Title = "Normal Stairs";
	tChart1.Draw();
And with these changes I got the attached image.
What I didn't mention in my last post is that we use .NET 3.5, and we solely compile a 32Bit version. The file version of TeeChart.dll is 4.1.2011.4192.
Hope this helps
Florian Treier
Result.zip
(3.2 KiB) Downloaded 276 times
Post by Sandra » Wed Jun 15, 2011 3:54 pm
Hello FT_GAIG,
Thank you, you are right. I have added back it in bug list report with number[TF02015615]to be try to fix for next maintenance releases of TeeChart.Net.
