Hello
I just bought teechart 2010 and cannot load the project Direct2DDemo2010.csproj
I get the error message as shown in the attachment.
Any ideas?
I am running Windows 7 ultimate with Visual Studio 2010
Andrew
Cant load Direct2DDemo2010.csproj
- Visual Studio 2010 error message
- ErrorWhenLoadingProject.PNG (25.6 KiB) Viewed 17901 times
Re: Cant load Direct2DDemo2010.csproj
Hello Andrew,
I could reproduce it problem and I have solved it doing next steps:
- 1.- Open with text editor(notepad, notepad++,...) Direct2DDemo2010.csproj
2.- Remove next lines, that you will find end of file.3.- Try again to load project.Code: Select all
<HintPath>C:\Program Files\Steema Software\TeeChart for .NET Digital Signal Processing\net40\TeeChart.Direct2D.dll</HintPath> <HintPath>C:\Program Files\Steema Software\TeeChart for .NET Digital Signal Processing\net40\TeeChart.dll</HintPath>
4- Go to folder references and remove: TeeChart ,TeeChart.Direct2D
5.- Add again files TeeChart.dll and TeeChart.Direct2D.dll, that you find in the folder \...\Steema Software\TeeChart for .NET Digital Signal Processing\net40
6.- Clean solution and build it again
7.- Run project.
Hi Sandra,
Yes your suggestions worked and I can now compile and run the example.
Ok, another problem.I left the sample running and after a few minutes I get an out of memory exception. All types of graph caused this problem, speed demo, signal throughput, signal input etc.
If you run the sample you will see that the memory slowly increases. I checked simple things like you were deleting points from the series. It seems the only way of stopping the memory leak is to comment out the line tChart.Invalidate()
I think something is happening internally, either with the TeeChart control or SlimDX system. I am fairly familair with the TeeChart fastline series and I have not noticed any issues with the non Direct2D version of the DLL.
Please confirm if you find the same problem.
Thank you
Andrew
Thank you
Andrew
protected override void DoTimerTick()
tChart.AutoRepaint = false;
for (int i = 0; i < 500; i++)
fastLine.Add(count, rnd.Next(100, 500));
++count;
tChart.Axes.Bottom.SetMinMax(fastLine.XValues.Maximum - 10000, fastLine.XValues.Maximum);
if (fastLine.Count >= 20000)
fastLine.Delete(0, 10000);
tChart.AutoRepaint = true;
tChart.Invalidate();
PointsPerFrame = (int)Math.Round(fastLine.XValues.Maximum - tChart.Axes.Bottom.Minimum);
base.DoTimerTick();
Hello!
Yup, I've confirmed it here. We'll try to have this fixed for the next maintenance release, due out in a couple of weeks time.StupidInstaller wrote: Please confirm if you find the same problem.
Thank you!
http://groups.google.com
http://codenewsfast.com/
Hello Adrew,
I inform, that you can find a new version of TeeChartDirect2D. You can download it in the next link: http://www.steema.com/clientaccess
