Axis.Automatic with a margin
ctusch
Post by ctusch » Thu Oct 28, 2010 8:06 am
when I have Axis.Automatic = true and there are two lines assigned to this axis and the first runs at y=1 and the second at y=3 then my axis min will be 1 and my max will be 3. The problem is when my series are just straight lines they are not visible because they are exactly at the borders of the chart. So i would need some kind of margin so that the min/max of the axis is always some pixels more than the actual min/max.
How can I do this? Is there a build-in functionality for this?
ctusch
Re: Axis.Automatic with a margin
Post by ctusch » Thu Oct 28, 2010 9:01 am
Okay, I've found it! :) Axis.MinimumOffset & Axis.MaximumOffset do the job perfectly.
Post by Sandra » Thu Oct 28, 2010 10:26 am
Hello ctusch,
I am glad that you found a solution for your problem :).
ctusch
Post by ctusch » Tue Dec 21, 2010 9:21 am
seems like I was too hasty. Axis.MinimumOffset & Axis.MaximumOffset work only when Axis.Automatic is set to false. That's a big problem as one of our customers needs automatic axis scaling. What can I do about this?
Post by Sandra » Tue Dec 21, 2010 1:03 pm
Hello ctusch,
I couldn't reproduce your problem using last version of TeeChart.Net and next code:
        private Steema.TeeChart.Styles.Line line1, line2;
        Steema.TeeChart.TChart tChart1;
        Steema.TeeChart.ChartController ChartController;
           this.tChart1 = new Steema.TeeChart.TChart();
           this.ChartController = new Steema.TeeChart.ChartController();
            this.Controls.Add(tChart1);
            this.Controls.Add(ChartController);
            this.tChart1.Left = 100;
            this.tChart1.Top = 50;
            ChartController.Chart = tChart1;
            line1 = new Steema.TeeChart.Styles.Line(tChart1.Chart);
            line2 = new Steema.TeeChart.Styles.Line(tChart1.Chart);
            Random rnd = new Random();
            for (int i = 0; i < 10; i  )
                line1.Add(i, rnd.Next(10));
                line2.Add(i, rnd.Next(10));
            tChart1.Axes.Left.MinimumOffset = 50;
            tChart1.Axes.Left.MaximumOffset = 70;
Please, check if previous code works as you want? If it doesn't work for you could you tell us which version of TeeChart.Net are you using.
ctusch
Post by ctusch » Tue Dec 21, 2010 1:23 pm
It doesn't work here, it looks like this:
I'm using version 3.5.3700.30575.
Post by Sandra » Tue Dec 21, 2010 2:55 pm
Hello ctusch,
Your problem is solved in last version of TeeChart.Net (version 4) and in it version works correctly. For version 3 there are a workaround using StartPosition and EndPosition:
            for (int i = 0; i < 10; i++)
            tChart1.Axes.Left.StartPosition = 10;
            tChart1.Axes.Left.EndPosition = 95;
Could you please, tell us if previous code is a good solution for you?
ctusch
Post by ctusch » Tue Dec 21, 2010 3:18 pm
Hello Sandra,
your workaround works, thanks for your help!
