Drawlines and Custom vertical Axis
Snarkle
Post by Snarkle » Wed Sep 22, 2010 1:43 am
Greetings,
I cannot seem to place a drawline on a chart area that uses a custom axis. as per below.
cutAxis and Drawline.png (14.25 KiB) Viewed 5331 times
And as you can see in the above pic even when I drag a drawline over a custom axis the drag handle disapears, I cannot place a drawline using the mouse at all.
How can this be done?
Cheers Phil.
Cheers Phil.
Re: Drawlines and Custom vertical Axis
Post by Sandra » Thu Sep 23, 2010 10:18 am
Hello Phil,
Could you please send us a simple example, because we can reproduce your problem here?
Snarkle
Post by Snarkle » Fri Sep 24, 2010 3:47 am
Included is an app to demonstrate ... try dragging a drawline on the custom axis part .. you cant place a drawline there .. you cant create the drawline there ...
in my application I have the same behaviour .. I cant use drawlines with custom axes
ValueLine (2).zip
(59.62 KiB) Downloaded 330 times
Cheers Phil.
Post by Sandra » Fri Sep 24, 2010 1:37 pm
Hello Phil,
Thanks for your example. I can reproduce the problem here and I have added your request in bug list with number [TF02015170].We will try to fix it for next maintenance releases.
Snarkle
Post by Snarkle » Mon Sep 27, 2010 1:11 am
Oh dear thats not god news for my deadline ... um when is the next maintenance release due for release ... time to do do some creative project scheduling ... can you confirm or deny whether this fix and another bug fix for the point and figure chart will be in the next maintenance release ? and when its due for release to the wild world ...
Cheers Phil.
Cheers Phil.
Post by Narcís » Mon Sep 27, 2010 7:07 am
Hi Phil,
I think the version is due out in a couple of weeks. At the present moment I'm not able to confirm those issues (TF02015170 and TF02015088) will be fixed for the next maintenance release.
