trend line problem
luzhetsky
trend line problem
Post by luzhetsky » Fri Aug 06, 2010 12:10 pm
Hi Steema team!
Please help us to fix problem with drawing trend line: it is not drawing in right part of the chart.
We use v4.0.2009.42281 (in v2010 we see the same problem).
We need instructions how to fix it in the sources.
Here is a code (draw line after pushing button):
            Line line = new Line();
            line.FillSampleValues();
            tChart1.Series.Add(line);
            DrawLine tool = new DrawLine();
            tChart1.Tools.Add(tool);
            tool.Series = line;
            tool.EnableDraw = true;
            tool.EnableSelect = true;
and example screenshort in the attach.
Thank you.
Re: trend line problem
Post by Sandra » Tue Aug 10, 2010 11:19 am
Hello luzhetsky,
Sorry for delay. I couldn't reproduce your problem using your code and last maintenance release of TeeChart.Net 2010. Could you please, update your version of TeeChart . Net and checked if your project works correctly?
luzhetsky
Post by luzhetsky » Thu Aug 12, 2010 11:39 am
Hi Sandra!
Unfortunately, wу can't setup TeeChartNET2010Src_4.1.2010.08040.exe - it says "Online Licence activation has failed."
We have tried to install TeeChartNET2010Src_4.0.2010.27960.exe - it has been installed ok, but problem is still presenting in this version.
We are using Windows XP and VS 2008, 2010.
Could you please tell us what need to do to install 4.1 version?
Thank you.
PS: we have intsalled binary of 4.1 - looks it works ok, but we need sources - we build it in our project with some our fixes.
Post by Sandra » Thu Aug 12, 2010 12:54 pm
Hello luzhetsky,
Please contact our Sales Dept. at sales at steema dot com for further licensing issues.
