Axis.CalcPosValue() bug or RectTool bug
Avijit
Post by Avijit » Thu Aug 05, 2010 8:41 am
Hi All,
I am seeing a wired behaviour with CalcPosValue and RectTool.
I have attached the sample project so that you can run it 'as is' to reproduce the problem.
Once the form is loaded, just try to zoom before the rect tool starts.
Zoom very small area (2 pixel or something).
Now zoom again (same two pixel).
You would see the Recttool took the entire area.
This is wired.
Bug.zip
(34.57 KiB) Downloaded 593 times
See the screen shots below -
Bug.zip
Avijit
Screen Shots
Re: Axis.CalcPosValue() bug or RectTool bug
Post by Sandra » Mon Aug 09, 2010 10:31 am
Hello Avijit,
I have tried run your project and seems that doesn't work fine here. Please, you could attach again your project, because we can run it here.
Avijit
Post by Avijit » Mon Aug 09, 2010 11:10 am
Hello Sandra,
I have attached the project again.
Bug.zip
(52.51 KiB) Downloaded 784 times
Avijit
Post by Sandra » Tue Aug 10, 2010 10:02 am
Hello Avijit,
Ok, I could reproduce your problem and I have added your request in bug list with number [TF02015082]. We will try to fix it in next maintenances releases of TeeChart.Net.
