ErrorBar Width Visible Issue
BISTEL
Post by BISTEL » Fri Jul 16, 2010 11:32 am
I use TeeChartNET2009VSNET2008_4.0.2009.62332.exe.
1. There is a problem in Error Bar Series Visible.
Red Series is ErrorBar.
At Chart Resize Width Change, ErrorBar Series not visible.
Re: ErrorBar Width Visible Issue
Post by Yeray » Fri Jul 16, 2010 2:46 pm
Hi BISTEL,
I'm trying to reproduce the problem with the following simple example project, but I can't:
            CreateChart();
        private Steema.TeeChart.TChart tChart1;
        private void CreateChart()
            tChart1 = new Steema.TeeChart.TChart();
            this.Controls.Add(tChart1);
            Steema.TeeChart.ChartController chartController1 = new Steema.TeeChart.ChartController();
            this.Controls.Add(chartController1);
            chartController1.Dock = DockStyle.Top;
            Steema.TeeChart.Styles.ErrorBar errorbar1 = new Steema.TeeChart.Styles.ErrorBar(tChart1.Chart);
            errorbar1.Add(500, 0, 320);
            line1.Pointer.Visible = true;
            for (int i = 0; i < 100; i++)
                line1.Add(i*10, i*3);
            tChart1.Axes.Bottom.SetMinMax(0, 1000);
Could you please check if you can reproduce it in your machine and, if not, could you please modify it so we can reproduce the problem here?
