Histogram Stack overflow Exception
BISTEL
Post by BISTEL » Wed Jul 14, 2010 7:43 am
I Use TeeChart 2009 or 2010
1. There is a problem In Histogram Zoom. ( Stack Overflow )
attached test code Project(HistogramTest.zip) Work In TeeChart 3.0
but TeeChart 2009 or 2010 has Problem. (stack overflow)
In My Opinion, If histogram color value count is more than 2 there is problem in Chart Screen Zoom.
2. Histogram Fill Color does not work. and Color Bar series same problem.
HistogramTest.zip
(27.24 KiB) Downloaded 309 times
test : Run -> Zoom -> See the Error Popup
Re: Histogram Stack overflow Exception
Post by Sandra » Wed Jul 14, 2010 11:57 am
Hello Bistel,
I couldn't reproduce your problems here with your code and last version of TeeChart.Net. Could you please tell us which steps we must follow for reproduce exactly your problem?
BISTEL
Post by BISTEL » Wed Jul 14, 2010 12:04 pm
step 1 : Run
step 2 : Zoom more than 4 or 5.
Post by Sandra » Thu Jul 15, 2010 9:48 am
Hello BISTEL,
Thanks for your explanation. I could reproduce your problem with last version of TeeChart .Net and I have added it in Bug Report list with number [TF02015029]. We will try to fix it for next maintenances releases of TeeChart.Net.
On the other hand, Could you please tell us exactly, what is the version that Histogram works fine for you? So, this would help us identifying the problem.
BISTEL
Post by BISTEL » Fri Jul 16, 2010 1:22 am
I use TeeChart 2009
In the number [TF02015029], is it include the this problem about fill the histogram Color(Color.Transparent)?
Post by Sandra » Fri Jul 16, 2010 10:10 am
Hello Blister,
I have apologised you, because I have forgotten of checked the problem that you have with Color.Transparent. Now, I have added it as a bug in bug list with number [TF02015033]. We will try to fix it in next maintenances releases of TeeChart.Net.
Also, Could you please tell us exactly number of version where histogram works fine for you? You find the number of version in file Release.txt of TeeChart.Net.
BISTEL
Post by BISTEL » Fri Jul 16, 2010 10:14 am
I use TeeChartNET2009VSNET2008_4.0.2009.62332.exe.
Post by Sandra » Fri Jul 16, 2010 10:26 am
Hello Blister,
Thanks for your information, but I refer to number of version 3, that you commented previously that Histogram works correctly:
