Logarithmic scale bug
neurosoft
Post by neurosoft » Wed May 12, 2010 12:26 pm
In the attachment there are two TChart with logarithmic scale and the same data. First is WPF TChart (ver. 4.0.2010.13053), second WinForms TChart (ver. 2.0.2987.19069).
You can see: pictures are quite different! Why??
neurosoft
Re: Logarithmic scale bug
Post by neurosoft » Wed May 12, 2010 12:43 pm
You can easy check correctness of WPF TChart with logarithmic scale: make TChart with logarithmic Y axis, set MinValue to 100, MaxValue to 1000 and add one point with Y = 316.2 ( it is sqrt (100*1000)). This point must be in the middle of TChart between bottom and top. And it will not be in the middle!
neurosoft
Post by neurosoft » Fri May 14, 2010 9:29 am
Steema people, please!
Did you check this issue? It's critical because of wrong data presentation! Can you fix it?
Post by Yeray » Fri May 14, 2010 11:02 am
Hi neurosoft,
It seems that the axes' logarithmic property has been broken for some reason with the latest build (v4.0.2010.13052), with WinForms. In WPF it still seems to work fine.
I've added it to the defect list to be fixed asap (TF02014882). Thanks for reporting it.
Post by Yeray » Fri Jun 11, 2010 4:40 pm
Hi neurosoft,
We will close the (TF02014882) because both in WinForms and WPF the following code describes a straight line, which we think would be the expected:
            tChart1.Axes.Left.Logarithmic = true;
            tChart1.Axes.Left.SetMinMax(100, 1000);
            tChart1.Axes.Bottom.SetMinMax(0, 20);
            Steema.TeeChart.Styles.Points points1 = new Steema.TeeChart.Styles.Points(tChart1.Chart);
            //Steema.TeeChart.WPF.Styles.Points points1 = new Steema.TeeChart.WPF.Styles.Points(tChart1.Chart);
            for (int i = 0; i < 20; i++)
                points1.Add(i * (1000 - 100) / 20 + 100);
neurosoft
Post by neurosoft » Wed Jun 23, 2010 11:08 am
Hi Yeray!
Logarithmic scale bug is very serious!
I have changed your sample a little to see points from 10 to 1000.
Please see attached pictures
Picture N 1 (WPF TChart Version=4.0.2010.27963, logarithmic scale) is wrong! It's look like Picture N 2 (WPF TChart Version=4.0.2010.27963, linear scale).
Picture N 1 must be look like as Picture 3 (Windows Forms TChart Version=2.0.2987.19069, logarithmic scale)! Picture 4 (Windows Forms TChart Version=2.0.2987.19069, linear scale) is here only to compare with others.
Please fix this bug, it's very serious, because of it we have to use old TChart versions and can't go to using WPF TChart!!
neurosoft
Post by neurosoft » Tue Jun 29, 2010 1:23 pm
Hi, Steema people!
Why didn't you response to my cry from the heart? Can you fix this bug with logarithmic axes? Because of this bug it's impossible to use latest TChart!
Post by Yeray » Wed Jun 30, 2010 6:47 am
Hi neurosoft,
We haven't forgotten this. We are investigating it and we'll be back here asap.
Post by Yeray » Wed Jun 30, 2010 11:59 am
Hi neurosoft,
We've found the problem and solved it. The fix will be available with the next maintenance release.
In the meanwhile here it is an ugly workaround:
After: tChart1.Axes.Left.Logarithmic = true;
Run: tChart1.Axes.Left.Horizontal = tChart1.Axes.Left.Horizontal;
neurosoft
Post by neurosoft » Fri Jul 02, 2010 9:44 am
Hi Yeray!
It works! Thank you!!
