Bar Graphs - orienatation
UserLS
Post by UserLS » Sat Mar 27, 2010 4:57 am
I have a bar graph with origin set in a such a way so some of the bars are above the line, while the others are below it.
If bar style is set to Cone (or Inverted Cone) then all the cones will either start or end on the origin line (which is fine!)
Please note, though, that the cones below origin line are using border color to paint the cone and the brush color to draw the borders... strange.
But if I change the style to Arrow or Pyramid (or their inverted versions) the situation is totally different!
Now all of them will start or end at the bottom! What I'd like, is a graph where my arrows are either all pointing towards the origin line or away from it (same with pyramids). Can it be just another option, so it would work for us and not break someone else's graphs?
Also, the Cylinder looks just really strange:
Since you can see bottoms of some of them and tops of the others, it just looks broken (especially since rectangles do not have this problem).
Re: Bar Graphs - orienatation
Post by Sandra » Mon Mar 29, 2010 12:30 pm
Hello UserLs,
I have added your suggestion in bug report list with number [TF02014760]. We will try to fix for next versions of TeeChart .Net
Post by Sandra » Thu Jun 17, 2010 9:06 am
Hello UserLs,
I inform that bug wit number (TF02014760) works correctly now and it should work as expected in the next maintenance release.
