Negative numbers
UserLS
Negative numbers
Post by UserLS » Thu Mar 18, 2010 2:45 pm
I still have not found a single place in TChart, where negative numbers are valid selections and do work correctly.
  • Shadows with negative offsets are finally showing up, but anything, which needs to be adjusted for the shadow is either adjusting in wrong direction (headers and footers) or simply do nothing (legend title).
  • Anything, which allows rotation produces completely different results for angles 315 and -45 (which is the same angle!) - look at marks or axis labels for examples.
Re: Negative numbers
Post by Sandra » Fri Mar 19, 2010 11:58 am
Hello UserLs,
The problem is already known to us with number (TF02014606). I have increased its priority.
I couldn't reproduce your problem using next code:
        Steema.TeeChart.Styles.Bar bar1;
            tChart1.Header.Visible = true;
            bar1 = new Steema.TeeChart.Styles.Bar(tChart1.Chart);
            bar1.FillSampleValues();
            bar1.Pen.Visible = false;
            tChart1.Header.Font.Shadow.Visible = true;
            tChart1.Header.Font.Shadow.Width = -9;
            tChart1.Header.Font.Shadow.Height= -9;
Please, you could say if you can reproduce the problem using previously code?
UserLS
Post by UserLS » Fri Mar 19, 2010 5:49 pm
Here I've set legeng title shadow offsets to (-20, -20) so the problem is more visible:
You cannot see the shadow and the title is running out of the legend box.
If I am using offsets (20, 20) - the shadow now is outside the legend box:
After I started to call Chart.Refresh() before saving it to file, legend at least tries to recalc its rectangle for the negative shadows.
UserLS
Post by UserLS » Fri Mar 19, 2010 5:59 pm
For the headers as you can see shadow with negative offsets (-20, -20) do not show up, but the graph is trying to recalc positions to accommodate the shadow. As I suspect, the problem here - offsets are treated as positive numbers and threrefore parts of graph are running onto each other.
The next image is using positive, but big offsets, just to show, that shadows still have major probles (ironically, a lot better behavior is demonstrated by shapes with round rectangle!)
Post by Sandra » Mon Mar 22, 2010 11:38 am
Hello UserLs,
I could reproduce your problems with shadow and I have added in list bug report with number [TF02014741]. We will try to fix for next versions release of TeeChart.Net
