Problems loading/compiling a cs-file that contains teeChart
SurveyBob
Post by SurveyBob » Mon Jan 18, 2010 4:31 pm
I created a cs file that contains a teeChart - contour- object ( Windows XP, Visual Studio 2008). Editing (right click on the object, edit, change one property) the control in design mode leads to VS to get stuck in "Not responding" mode.
Saving the file that contains the teeChart object leads to large cpu usage and eventually low memory of VS.
The teeChart version I am using is 4.0.2009.42283
private void InitializeComponent()
			System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager( typeof( ContourMap ) );
			this.tChart1 = new Steema.TeeChart.TChart();
			this.contour1 = new Steema.TeeChart.Styles.Contour();
			this.points1 = new Steema.TeeChart.Styles.Points();
			this.SuspendLayout();
			// tChart1
			this.tChart1.Aspect.View3D = false;
			this.tChart1.Aspect.ZOffset = 0;
			this.tChart1.Axes.Bottom.Grid.Color = System.Drawing.Color.FromArgb( ( (int) ( ( (byte) ( 64 ) ) ) ), ( (int) ( ( (byte) ( 64 ) ) ) ), ( (int) ( ( (byte) ( 64 ) ) ) ) );
			this.tChart1.Axes.Bottom.Labels.OnAxis = false;
			this.tChart1.Axes.Bottom.Labels.RoundFirstLabel = false;
			this.tChart1.Axes.Bottom.Labels.Style = Steema.TeeChart.AxisLabelStyle.Value;
			this.tChart1.Axes.Bottom.Labels.ValueFormat = "0.0";
			this.tChart1.Axes.Bottom.MaximumOffset = 4;
			this.tChart1.Axes.Bottom.MinimumOffset = 4;
			this.tChart1.Axes.Bottom.MinorTickCount = 1;
			this.tChart1.Axes.Bottom.StartPosition = 3;
			this.tChart1.Axes.Bottom.TicksInner.Visible = true;
			this.tChart1.Axes.Bottom.Title.Transparent = true;
			this.tChart1.Axes.Bottom.Title.Visible = false;
			this.tChart1.Axes.Depth.Title.Transparent = true;
			this.tChart1.Axes.DepthTop.Title.Transparent = true;
			this.tChart1.Axes.DrawBehind = false;
			this.tChart1.Axes.Left.Labels.OnAxis = false;
			this.tChart1.Axes.Left.MaximumOffset = 4;
			this.tChart1.Axes.Left.MinimumOffset = 4;
			this.tChart1.Axes.Left.StartPosition = 3;
			this.tChart1.Axes.Left.Title.Transparent = true;
			this.tChart1.Axes.Right.Title.Transparent = true;
			this.tChart1.Axes.Right.Visible = false;
			this.tChart1.Axes.Top.Automatic = false;
			this.tChart1.Axes.Top.AutomaticMaximum = false;
			this.tChart1.Axes.Top.AutomaticMinimum = false;
			this.tChart1.Axes.Top.Maximum = 0;
			this.tChart1.Axes.Top.Minimum = 0;
			this.tChart1.Axes.Top.Title.Transparent = true;
			this.tChart1.Cursor = System.Windows.Forms.Cursors.Default;
			this.tChart1.Dock = System.Windows.Forms.DockStyle.Fill;
			this.tChart1.Header.Lines = new string[] {
        "Contour map"};
			this.tChart1.Legend.Font.Brush.Color = System.Drawing.Color.FromArgb( ( (int) ( ( (byte) ( 0 ) ) ) ), ( (int) ( ( (byte) ( 0 ) ) ) ), ( (int) ( ( (byte) ( 255 ) ) ) ) );
			this.tChart1.Legend.LegendStyle = Steema.TeeChart.LegendStyles.Values;
			this.tChart1.Legend.TextStyle = Steema.TeeChart.LegendTextStyles.Value;
			this.tChart1.Location = new System.Drawing.Point( 0, 0 );
			this.tChart1.Name = "tChart1";
			this.tChart1.Series.Add( this.contour1 );
			this.tChart1.Series.Add( this.points1 );
			this.tChart1.Size = new System.Drawing.Size( 813, 807 );
			this.tChart1.TabIndex = 0;
			// contour1
			this.contour1.Brush.Color = System.Drawing.Color.FromArgb( ( (int) ( ( (byte) ( 68 ) ) ) ), ( (int) ( ( (byte) ( 102 ) ) ) ), ( (int) ( ( (byte) ( 163 ) ) ) ) );
			this.contour1.Brush.Visible = false;
			this.contour1.Color = System.Drawing.Color.FromArgb( ( (int) ( ( (byte) ( 68 ) ) ) ), ( (int) ( ( (byte) ( 102 ) ) ) ), ( (int) ( ( (byte) ( 163 ) ) ) ) );
			this.contour1.ColorEach = false;
			this.contour1.Cursor = System.Windows.Forms.Cursors.No;
			this.contour1.EndColor = System.Drawing.Color.FromArgb( ( (int) ( ( (byte) ( 255 ) ) ) ), ( (int) ( ( (byte) ( 0 ) ) ) ), ( (int) ( ( (byte) ( 0 ) ) ) ) );
			this.contour1.IrregularGrid = true;
			this.contour1.Marks.Bevel.ColorTwo = System.Drawing.Color.FromArgb( ( (int) ( ( (byte) ( 128 ) ) ) ), ( (int) ( ( (byte) ( 128 ) ) ) ), ( (int) ( ( (byte) ( 128 ) ) ) ) );
			this.contour1.Marks.Brush.Visible = false;
			this.contour1.Marks.Callout.ArrowHead = Steema.TeeChart.Styles.ArrowHeadStyles.None;
			this.contour1.Marks.Callout.ArrowHeadSize = 8;
			this.contour1.Marks.Callout.Brush.Color = System.Drawing.Color.Black;
			this.contour1.Marks.Callout.Distance = 0;
			this.contour1.Marks.Callout.Draw3D = false;
			this.contour1.Marks.Callout.Length = 10;
			this.contour1.Marks.Callout.Series = this.contour1;
			this.contour1.Marks.Callout.Style = Steema.TeeChart.Styles.PointerStyles.Rectangle;
			this.contour1.Marks.Callout.Visible = false;
			this.contour1.Marks.DrawEvery = 3;
			this.contour1.Marks.Series = this.contour1;
			this.contour1.Marks.Transparent = true;
			this.contour1.Marks.Visible = true;
			this.contour1.MidColor = System.Drawing.Color.FromArgb( ( (int) ( ( (byte) ( 128 ) ) ) ), ( (int) ( ( (byte) ( 0 ) ) ) ), ( (int) ( ( (byte) ( 128 ) ) ) ) );
			this.contour1.NumLevels = 12;
			this.contour1.NumXValues = 490;
			this.contour1.NumZValues = 490;
			this.contour1.PaletteMin = 0;
			this.contour1.PaletteStep = 0;
			this.contour1.PaletteSteps = 12;
			this.contour1.PaletteStyle = Steema.TeeChart.Styles.PaletteStyles.Pale;
			this.contour1.Pen.Color = System.Drawing.Color.FromArgb( ( (int) ( ( (byte) ( 255 ) ) ) ), ( (int) ( ( (byte) ( 255 ) ) ) ), ( (int) ( ( (byte) ( 255 ) ) ) ) );
			this.contour1.Pointer.HorizSize = 2;
			this.contour1.Pointer.Pen.Visible = false;
			this.contour1.Pointer.Series = this.contour1;
			this.contour1.Pointer.Style = Steema.TeeChart.Styles.PointerStyles.Rectangle;
			this.contour1.Pointer.VertSize = 2;
			this.contour1.Pointer.Visible = false;
			this.contour1.StartColor = System.Drawing.Color.FromArgb( ( (int) ( ( (byte) ( 0 ) ) ) ), ( (int) ( ( (byte) ( 0 ) ) ) ), ( (int) ( ( (byte) ( 255 ) ) ) ) );
			this.contour1.TimesZOrder = 5;
			this.contour1.Title = "contour1";
			this.contour1.ValueFormat = "0.0";
			this.contour1.XValues.DataMember = "X";
			this.contour1.YPosition = 0.20322339899792125;
			this.contour1.YValues.DataMember = "Y";
			this.contour1.ZValues.DataMember = "Z";
			// points1
			this.points1.Color = System.Drawing.Color.FromArgb( ( (int) ( ( (byte) ( 255 ) ) ) ), ( (int) ( ( (byte) ( 128 ) ) ) ), ( (int) ( ( (byte) ( 0 ) ) ) ) );
			this.points1.ColorEach = false;
			this.points1.Cursor = System.Windows.Forms.Cursors.SizeAll;
			this.points1.Depth = 0;
			this.points1.LinePen.Color = System.Drawing.Color.FromArgb( ( (int) ( ( (byte) ( 146 ) ) ) ), ( (int) ( ( (byte) ( 94 ) ) ) ), ( (int) ( ( (byte) ( 32 ) ) ) ) );
			this.points1.Marks.ArrowLength = 9;
			this.points1.Marks.Bevel.ColorOne = System.Drawing.Color.FromArgb( ( (int) ( ( (byte) ( 0 ) ) ) ), ( (int) ( ( (byte) ( 0 ) ) ) ), ( (int) ( ( (byte) ( 0 ) ) ) ) );
			this.points1.Marks.Bevel.ColorTwo = System.Drawing.Color.FromArgb( ( (int) ( ( (byte) ( 255 ) ) ) ), ( (int) ( ( (byte) ( 0 ) ) ) ), ( (int) ( ( (byte) ( 0 ) ) ) ) );
			this.points1.Marks.Brush.Color = System.Drawing.Color.FromArgb( ( (int) ( ( (byte) ( 255 ) ) ) ), ( (int) ( ( (byte) ( 255 ) ) ) ), ( (int) ( ( (byte) ( 255 ) ) ) ) );
			this.points1.Marks.Brush.Visible = false;
			this.points1.Marks.Callout.ArrowHead = Steema.TeeChart.Styles.ArrowHeadStyles.None;
			this.points1.Marks.Callout.ArrowHeadSize = 8;
			this.points1.Marks.Callout.Brush.Color = System.Drawing.Color.Black;
			this.points1.Marks.Callout.Dark3D = false;
			this.points1.Marks.Callout.Distance = 0;
			this.points1.Marks.Callout.Draw3D = false;
			this.points1.Marks.Callout.InflateMargins = false;
			this.points1.Marks.Callout.Length = 9;
			this.points1.Marks.Callout.Series = this.points1;
			this.points1.Marks.Callout.Style = Steema.TeeChart.Styles.PointerStyles.Rectangle;
			this.points1.Marks.Callout.Visible = false;
			this.points1.Marks.Font.Shadow.Brush.Color = System.Drawing.Color.FromArgb( ( (int) ( ( (byte) ( 255 ) ) ) ), ( (int) ( ( (byte) ( 255 ) ) ) ), ( (int) ( ( (byte) ( 255 ) ) ) ) );
			this.points1.Marks.Font.Shadow.Smooth = true;
			this.points1.Marks.Font.Shadow.SmoothBlur = 9;
			this.points1.Marks.Pen.Visible = false;
			this.points1.Marks.Series = this.points1;
			this.points1.Marks.Shadow.Visible = false;
			this.points1.Marks.ShapeStyle = Steema.TeeChart.Drawing.TextShapeStyle.RoundRectangle;
			this.points1.Marks.Symbol.Brush.Gradient.StartColor = System.Drawing.Color.FromArgb( ( (int) ( ( (byte) ( 255 ) ) ) ), ( (int) ( ( (byte) ( 255 ) ) ) ), ( (int) ( ( (byte) ( 255 ) ) ) ) );
			this.points1.Marks.Symbol.Brush.Gradient.Visible = true;
			this.points1.Marks.Symbol.Shadow.Visible = false;
			this.points1.Marks.Transparent = true;
			this.points1.Marks.Visible = true;
			this.points1.PercentFormat = "";
			this.points1.Pointer.Brush.Color = System.Drawing.Color.FromArgb( ( (int) ( ( (byte) ( 255 ) ) ) ), ( (int) ( ( (byte) ( 128 ) ) ) ), ( (int) ( ( (byte) ( 0 ) ) ) ) );
			this.points1.Pointer.Brush.ForegroundColor = System.Drawing.Color.Empty;
			this.points1.Pointer.Brush.Gradient.StartColor = System.Drawing.Color.FromArgb( ( (int) ( ( (byte) ( 243 ) ) ) ), ( (int) ( ( (byte) ( 156 ) ) ) ), ( (int) ( ( (byte) ( 53 ) ) ) ) );
			this.points1.Pointer.Dark3D = false;
			this.points1.Pointer.Draw3D = false;
			this.points1.Pointer.HorizSize = 3;
			this.points1.Pointer.Pen.Color = System.Drawing.Color.FromArgb( ( (int) ( ( (byte) ( 255 ) ) ) ), ( (int) ( ( (byte) ( 128 ) ) ) ), ( (int) ( ( (byte) ( 0 ) ) ) ) );
			this.points1.Pointer.Series = this.points1;
			this.points1.Pointer.Style = Steema.TeeChart.Styles.PointerStyles.Circle;
			this.points1.Pointer.VertSize = 3;
			this.points1.ShowInLegend = false;
			this.points1.Title = "points1";
			this.points1.TreatNulls = Steema.TeeChart.Styles.TreatNullsStyle.Ignore;
			this.points1.XValues.DataMember = "X";
			this.points1.XValues.Order = Steema.TeeChart.Styles.ValueListOrder.Ascending;
			this.points1.YValues.DataMember = "Y";
			// ContourMap
			this.Controls.Add( this.tChart1 );
			this.Name = "ContourMap";
			this.Size = new System.Drawing.Size( 813, 807 );
			this.ResumeLayout( false );
Thank you very much in advanced,
Stephan
Re: Problems loading/compiling a cs-file that contains teeChart
Post by Narcís » Tue Jan 19, 2010 4:02 pm
Hello Stephan,
Could you please attach a simple example project we can run "as-is" and/or let us know the exact steps we should follow to recreate the issue here?
SurveyBob
Post by SurveyBob » Thu Jan 21, 2010 10:39 am
Hello Narcis,
All I did was adding a TeeChart to a new Windows-Form, adding a contour series (2D) to the TeeChart and saved it. Following error message kept popping up every second.
Microsoft Visual Studio
Code generation for property 'Levels' failed. Error was: 'Type 'Steema.TeeChart.Styles.ContourLevel' in Assembly 'TeeChart, Version=2.0.2652.22325, Culture=neutral, PublicKeyToken=9c8126276c77bdb7' is not marked as serializable.'
OK
I saw this a few times also an different mashines.
Best regards,
Stephan
Post by Narcís » Thu Jan 21, 2010 11:19 am
Hi Stephan,
I'm not able to reproduce this here using latest TeeChart for .NET v2 build available at the client area. Can you please check if latest version available solves the problem at your end?
SurveyBob
Post by SurveyBob » Wed Jan 27, 2010 1:37 pm
Hi Narcís,
I attached a stand alone solution which is able to reproduce the issue. I had the lastest version ( 4.0.2009.42283) installed.
Best regards,
Stephan
FYI, the error message I posted earlier has been cause by the fact, that I had 2 version of teeChart installed on my machine.
I removed the earlier one and the message was gone
TeeChartTestSolution.zip
(19.92 KiB) Downloaded 471 times
Post by Sandra » Thu Jan 28, 2010 10:53 am
Hello SurveyBob,
I couldn't reproduce the problem here using last version of TeeChart.Net. Please you can say exactly what steps we must to reproduce the error?
SurveyBob
Post by SurveyBob » Fri Jan 29, 2010 9:26 am
Hello Sandra,
Here the steps I do to reproduce the problem.
-Open the TeeChartTestSolution form the earlier post
-Open the Form1.cs in Desinger View
-right click on the view
-select "Edit..."
-doubleclick contour1
-select General and unhook the "Show in Legend" tick box
-close the editor
-save the form
It takes app. 7 minutes to save the form. Visual Studio is running with high CPU load. "System out of memory" exceptions are thrown by Visual Studion after a while.
I have Visual Studio 2008 with SP1 installed, running on a 32 bit Windows XP (SP 3) machine.
Best reagards,
SurveyBob
Post by Sandra » Mon Feb 01, 2010 11:28 am
Hello SurveyBob,
I found that problem occurs because the number of points of NumXValues and NumZValues are too high. I recommend change values of NumXValues a NumZValues for example:
			this.contour1.NumLevels = 20;
			this.contour1.NumXValues = 100;
			this.contour1.NumZValues = 100;
Previous code works correctly. Please check it works if you want.
