Problem Graphic 3D
"Alias"
Problem Graphic 3D
Post by "Alias" » Thu Dec 17, 2009 1:42 pm
I have a problem when I use the tchart.aspect.elevation . My graphic do not goes from 0 to 360, it accepts this values but the image don't spin. I don't know if it's a limitation or there's something that I have to do.
Here is my code:
Private Function plotarBoia(ByVal g As Steema.TeeChart.Drawing.Graphics3D) As Boolean
        Try
            '// center position
            Dim Xcentro As Integer = g.ChartXCenter + g.RotationCenter.X
            Dim Ycentro As Integer = g.ChartYCenter + g.RotationCenter.Y
            Dim Zcentro As Integer = (tChart.Aspect.Width3D / 2) + g.RotationCenter.Z
            g.Brush.Solid = True
            g.Brush.Visible = True
            g.Pen.Visible = True
            g.Pen.Width = 1
            g.Pen.Color = Color.Black
            Dim rect As System.Drawing.Rectangle
            'Parte de baixo
            g.Brush.Color = Color.Orange
            rect = New System.Drawing.Rectangle(Xcentro - 96, Ycentro + 22, 192, 43)
            g.Cone(True, rect, Zcentro - 96, Zcentro + 96, True, 100)
            ''Parte do meio
            g.Brush.Color = Color.Gray
            rect = New System.Drawing.Rectangle(Xcentro - 104, Ycentro + 10, 208, 12)
            g.Cone(True, rect, Zcentro - 104, Zcentro + 104, True, 100)
            'Parte de cima
            rect = New System.Drawing.Rectangle(Xcentro - 96, Ycentro, 192, 10)
            Dim m(4) As Drawing.Point3D
            g.Brush.Color = Color.Yellow
            m(0) = New Steema.TeeChart.Drawing.Point3D(Xcentro - 50, Ycentro - 135, Zcentro) 'sup. dir.
            m(1) = New Steema.TeeChart.Drawing.Point3D(Xcentro - 50, Ycentro - 20, Zcentro) 'inf. dir.
            m(2) = New Steema.TeeChart.Drawing.Point3D(Xcentro - 100, Ycentro - 20, Zcentro) 'inf. esq.
            m(3) = New Steema.TeeChart.Drawing.Point3D(Xcentro - 100, Ycentro - 40, Zcentro) 'int. esq.
            m(4) = New Steema.TeeChart.Drawing.Point3D(Xcentro - 70, Ycentro - 135, Zcentro) 'sup. esq.
            g.Polygon(m)
            g.Pen.Width = 1
            'mastro
            g.Brush.Color = Color.Gainsboro
            rect = New System.Drawing.Rectangle(Xcentro - 50, Ycentro - 155, 8, 155)
            g.Cone(True, rect, Zcentro - 4, Zcentro + 4, True, 100)
            Dim p(3) As System.Drawing.Point
            p(0) = New System.Drawing.Point(Xcentro - 60, Ycentro - 155)
            p(1) = New System.Drawing.Point(Xcentro - 30, Ycentro - 155)
            p(2) = New System.Drawing.Point(Xcentro - 30, Ycentro - 155)
            p(3) = New System.Drawing.Point(Xcentro - 60, Ycentro - 155)
            g.Plane(Zcentro - 25, Zcentro + 25, p)
            g.Brush.Color = Color.White
            'est. met.
            rect = New System.Drawing.Rectangle(Xcentro - 55, Ycentro - 195, 4, 40)
            g.Cone(True, rect, Zcentro + 18, Zcentro + 22, True, 100)
            'gps
            rect = New System.Drawing.Rectangle(Xcentro - 39, Ycentro - 175, 4, 20)
            'sinalizador
            rect = New System.Drawing.Rectangle(Xcentro - 51, Ycentro - 190, 12, 35) '45
            g.Cone(True, rect, Zcentro - 6, Zcentro + 6, True, 100)
            rect = New System.Drawing.Rectangle(Xcentro - 40, Ycentro - 165, 6, 10)
            g.Cone(True, rect, Zcentro - 23, Zcentro - 17, True, 100)
            'antena
            rect = New System.Drawing.Rectangle(Xcentro - 55, Ycentro - 200, 4, 45)
            g.Cone(True, rect, Zcentro - 22, Zcentro - 18, True, 100)
            Return True
        Catch ex As Exception
            Return False
        End Try
    End Function
Thanks..! :)
Re: Problem Graphic 3D
Post by Narcís » Thu Dec 17, 2009 4:07 pm
Hi Alias,
Try setting the chart to be non-orthogonal:
TChart1.Aspect.Orthogonal = False
"Alias"
Post by "Alias" » Thu Dec 17, 2009 4:29 pm
it is set to be non-orthogonal
my image is rotating, but not correctly, it do not complete a round.
here is the code where I set the tchart:
Private Function criaGrafico() As Boolean
        Try
            tChart.Series.Clear()
            tChart.Visible = False
            tChart.Series.Add(points3D)
            tChart.Location = New System.Drawing.Point(8, 8)
            tChart.Size = New System.Drawing.Size(575, 450)
            alteraCorFundo(Color.Navy, Color.DeepSkyBlue, Color.Navy)
            '// tChart1
            '// tChart1.Axes
            tChart.Axes.Visible = False
            '// tChart1.Legend
            'tChart1.Legend.Shadow.Visible = True
            tChart.Legend.Visible = True
            tChart.Walls.Visible = False
            tChart.Aspect.Orthogonal = False
            tChart.Aspect.View3D = True
            tChart.Visible = True
            tChart.Enabled = True
            plotarBoia(tChart.Graphics3D)
            Return True
            Return False
        End Try
    End Function
thanks!
Post by Sandra » Fri Dec 18, 2009 10:22 am
Hello "Alias",
I couldn't reproduce your problem here. I have checked 3 different ways:
- I add Rotate Tool Chart.
-Using ChartEditor/3D.
-Using CharController rotate.
Using first and second way chart rotate 360º. On the other hand, using ChartController you can only rotate of 270º to 360º, because it's limited.
Please, you could send us a simple project because we can reproduce problem here? You could attach your project directly in the post.
"Alias"
Post by "Alias" » Fri Dec 18, 2009 12:48 pm
You can see the problem when you change the value of the Elevation (using the trackbar)
(I didn't attach my TeeChart.dll 4.0.2009.28593 because it's too big)
Thank you!
ProjectTChart.zip
A simple project
(154.67 KiB) Downloaded 377 times
Post by Sandra » Mon Dec 21, 2009 12:06 pm
Hello "Alias",
I found that your problem is that you assigned Zcentro. I change your custom drawing cone for a series pie because it has more properties, elevation works correctly and you have not draw many times chart. You can use a similar code in your application if you want add pie:
Dim pie1 As Steema.TeeChart.Styles.Pie
    Private Sub InitializeChart()
        pie1 = New Steema.TeeChart.Styles.Pie(tChart1.Chart)
        pie1.FillSampleValues(1)
        pie1.Marks.Visible = false
        pie1.ColorEach = false
        pie1.Color = Color.Orange
        chartController1.Chart = tChart1
        tChart1.Location = New Point(8, 8)
        tChart1.Size = New Size(575, 450)
        tChart1.Axes.Visible = false
        tChart1.Legend.Visible = true
        tChart1.Walls.Visible = false
        tChart1.Aspect.Orthogonal = false
        tChart1.Aspect.View3D = true
        tChart1.Visible = true
    Private Sub alteraCorFundo(ByVal startColor As Color, ByVal middleColor As Color, ByVal endColor As Color)
        tChart1.Panel.Brush.Gradient.EndColor = endColor
        tChart1.Panel.Brush.Gradient.MiddleColor = middleColor
        tChart1.Panel.Brush.Gradient.StartColor = startColor
    Private Sub trackBar1_ValueChanged(ByVal sender As Object, ByVal e As EventArgs)
        tChart1.Aspect.Elevation = trackBar1.Value
On the other hand, if you would use custom drawing and you would works correctly, you must change value of Z (Zcentro variable), because actually in your application Zcentor is static, if you don't change value will remain always the same position and will never be negative, therefore not work correctly.
"Alias"
Post by "Alias" » Mon Dec 21, 2009 5:08 pm
series pie don't work for me ( or I don't know how to make it works in my case )
changing the value of Zcentro neither works. The elevation rotates the axis, so it wouldn't work. When you use the rotation and tilt the values of Xcentro and Ycentro doesn't change.
you have any other idea?
thanks..!
Post by Sandra » Wed Dec 23, 2009 10:21 am
Hello Alias,
I modify your code, simplifying in same project, elevation and drawing cone. There seems to behave correctly here.
Please, see next code check works fine.
        AddHandler tChart1.AfterDraw, AddressOf Me.tChart1_AfterDraw
        tChart1.Draw
    Private Sub tChart1_AfterDraw(ByVal sender As Object, ByVal g As Steema.TeeChart.Drawing.Graphics3D)
        drawCone(g)
    Private Sub drawCone(ByVal g As Steema.TeeChart.Drawing.Graphics3D)
        Xcentro = (g.ChartXCenter + g.RotationCenter.X)
        Ycentro = (g.ChartYCenter + g.RotationCenter.Y)
        Zcentro = ((tChart1.Aspect.Width3D / 2)  _
                    + g.RotationCenter.Z)
        Dim rect As Rectangle = New Rectangle((Xcentro - 96), (Ycentro + 22), 192, 43)
        g.Pen.Visible = true
        g.Pen.Width = 1
        g.Cone(true, rect, (Zcentro + 96), (Zcentro - 96), true, 100)
        Text = tChart1.Aspect.Rotation.ToString
On the other hand,I believe as I said before should try controlled Z because it is not default controlled when you use custom drawing, as isn't case of x and y, because they are controlled by default.
"Alias"
Post by "Alias" » Tue Jan 12, 2010 1:09 pm
I checked and the elevation still doesn't working and changing the tilt value causes sometimes a problem in the cone.
How can I make Z controlled? What I have to do? Which properties I have to change? Is there any tool I have to add?
Thanks Sandra!
Post by Yeray » Tue Jan 12, 2010 4:59 pm
Hi Alias,
Could you please send us a simple example project we can run as-is to reproduce the problem here? Or, if the code that Sandra posted above reproduces the problem, could you please attach a picture of the result indicating where exactly is the problem you are seeing?
"Alias"
Post by "Alias" » Tue Jan 12, 2010 6:43 pm
I've already sent it.
Now I attached some pictures.
The trackbar values are going from -360 through 360.
The bottom of the object that I drew never appears.
Thanks!
Problem Elevation.
Problem Elevation. Note the white cylinders on the top.
problem of tilt using the Sandra's example.
"Alias"
Post by "Alias" » Tue Jan 12, 2010 7:08 pm
Another image.
Tilt problem. The cylinders of the top just disappeared.
"Alias"
Post by "Alias" » Thu Jan 14, 2010 7:20 pm
So, anyone knows how make the elevation works correctly? or not? this is a limitation of the teechart?
thanks !
"Alias"
Post by "Alias" » Mon Jan 18, 2010 10:43 am
Anybody? ?
Post by Yeray » Mon Jan 18, 2010 10:46 am
Hi Alias,
Excuse us for the delay,
I've reproduced the problem you show in your pictures and added it to the wish list to be revised for future releases (TF02014642). It may be a problem in the InternalCylinder function that gives an unexpected result for determined pair of z0 and z1 values [InternalCylinder(bool vertical, Rectangle r, int z0, int z1, bool dark3D, int conePercent)].
The simplest code I've found that reproduces the problem is this:
            tChart1.Axes.Visible = false;
            tChart1.Walls.Visible = false;
            tChart1.Aspect.Elevation = 350;
            tChart1.Aspect.Tilt = 270;
            int Xcentro = (g.ChartXCenter + g.RotationCenter.X);
            int Ycentro = (g.ChartYCenter + g.RotationCenter.Y);
            int Zcentro = ((tChart1.Aspect.Width3D / 2) + g.RotationCenter.Z);
            Rectangle rect = new Rectangle((Xcentro - 96), (Ycentro + 22), 192, 43);
            g.Pen.Visible = true;
            g.Brush.Color = Color.Orange;
            g.Cone(true, rect, (Zcentro + 96), (Zcentro - 96), true, 100);
