strange lines of AREA chart when window resized
Adrian
Post by Adrian » Sat Sep 19, 2009 7:17 am
Hi there,
I'm getting strange lines on an area chart when the window is resized, see the image below.
When the chart is created it looks fine, however, if I grab the corner of the window with the mouse and drag this is the result. I don't get this problem with any other series types lines, bars etc. only area charts.
The errant lines are the area border, if I set
linepen.visible=false
then I don't get the problem.
I'm using Tchart dotnet version 4.0.2009.28592.
Any ideas?
Re: strange lines of AREA chart when window resized
Post by Narcís » Mon Sep 21, 2009 8:17 am
Hello Adrian,
It would be really helpful if you could attach a simple example project we can run "as-is" and with which we can reproduce the problem here.
