Background color when trying to save or copy chart
DA
Post by DA » Tue May 25, 2004 9:25 am
There are two problems with background color.
1. When I set background color other than Transparent, it's always shown as black.
However transparent color is OK for me. But there's another problem.
2. When I'm trying to save chart
_chart.Export.Image.GIF.Save(fileName);
background color is always black for all formats. And when I'm trying to copy it
_chart.Export.Image.GIF.CopyToClipboard();
background color is always blue.
I've already tryed different formats. And I've got the same results when saving and copying chart in design mode.
Is this a bug or maybe something is wrong with my chart settings?
Version 1.1.1544.23908.
Post by Pep » Tue May 25, 2004 10:37 am
yes, you're correct, we're aware of these problems. And have added them to the list of defects for the TeeChart for .Net, meaning that a fix to them will be considered for inclusion into the mainenance release.
MTB
workaround -- partial solution
Post by MTB » Mon May 31, 2004 12:04 pm
I have a comment that I hope may help. I also have a related question.
First, I have found a workaround for this problem when copying charts to the clipboard at runtime. It may also work for printing, but I haven't tried it.
Instead of using Chart | Panel | Background | Color... in the TeeChart Editor, I use Chart | Panel | Background | Pattern... I can set the colors and even the background image in this dialog and those settings are used when I copy the chart.
The pattern dialog stills seems a bit buggy to me, but it overcomes the worst problems.
My question is that my bugs seem a bit different. While I get the blue background whenever I copy charts (unless I use the Pattern workaround), I have other problems with displaying the background color. Basically, I can't change it at all at runtime (unless I use the Pattern workaround). Transparency settings don't seem to have any effect for me.
Is this part of the same defect that is being addressed?
David
