chipshot
![Newbie Newbie](./images/ranks/1star.gif)
Post
by chipshot » Tue Feb 17, 2004 3:39 pm
I just purchased and installed the registered version and have had nothing but problems. Everything worked perfectly with the evaluation version but now everytime I drag a WebChart onto the designer in Visual Studion 2002 I get a ""Specified Cast Is Not Valid" in a gray box in the spot where the graph should be in the designer. I uninstalled the evaluation version prior to installing the purchased version and made sure that I used the intaller for VS 2002 as opposed to VS 2003. Any suggestions?
![Site Admin Site Admin](./images/ranks/6stars.gif)
Post
by Marc » Tue Feb 17, 2004 11:20 pm
Do the example WebChart projects work ok? The designtime code is included so it may be worth running and/or opening them as a check.
chipshot
Post
by chipshot » Fri Feb 20, 2004 2:18 am
I got it to work. I had to remove the reference to the demo version and add the new one.
