COMException during installation
wcedeno
Post by wcedeno » Mon Feb 02, 2004 4:18 pm
While installing TeeChart for .Net v1 I got the following error; "An exception System.Runtime.InteropServices.COMException has occurred in TEEGOF~1.EXE". After closing the JIT debugging window, the installation continued. I would like to know what failed during installation and how to fix the imcomplete installation in my system.
W
Post by Pep » Wed Feb 04, 2004 6:47 pm
do you have installed the MSDN Library ?
The installer EXE for the TeeChart for .NET will try to plug in the TeeChart for .NET Help files into one of the .NET MSDN library namespaces and will also try to install the TeeChart for .NET icons into the VS IDE - if you haven't got VS and MSDN installed on your machine then the installer will give you the errors you have experienced. We'll try to remedy this for the next installers.
wcedeno
Post by wcedeno » Wed Feb 04, 2004 7:28 pm
I do have MSDN July 2003 installed and VS.Net.
Post by Pep » Thu Feb 05, 2004 6:46 pm
also, do you have the Net Framework v1.1 installed ? I remember some customer with the same problem and the problem was the Net Framework version.
wcedeno
Post by wcedeno » Fri Feb 06, 2004 3:18 pm
I do have the .Net Framework v1.1 installed. My main concern now is to recover from the problem. I would like to get instructions as to what to do in order to complete the tasks that were not accomplished by the installation. Anything you could provide me will be appreciated.
W
Post by Christopher » Fri Feb 06, 2004 3:57 pm
Hi --
Please find following a copy of a successful INSTALL.LOG made on my machine:
  • *** Installation Started 08/05/2003 17:17 ***
    Title: TeeChart for .NET v1 Installation
    Source: C:\DOCUME~1\sirhc\LOCALS~1\Temp\GLB9D.tmp
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\UNWISE.EXE
    RegDB Key: Software\Microsoft\Windows\CurrentVersion\Uninstall\TeeChart for .NET v1
    RegDB Val: TeeChart for .NET v1
    RegDB Name: DisplayName
    RegDB Root: 2
    RegDB Val: C:\PROGRA~1\STEEMA~1\TEECHA~2.NET\UNWISE.EXE C:\PROGRA~1\STEEMA~1\TEECHA~2.NET\INSTALL.LOG
    RegDB Name: UninstallString
    RegDB Root: 2
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\Docs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Docs\NamedURLIndex_COL.HxK
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Docs\Steema.TeeChart_COL.HxA
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\Utils
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Utils\ToolBoxEditor.exe
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\Compact Framework
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\Compact Framework\Readme.txt
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\Compact Framework\PocketDemo.sln
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\Compact Framework\PocketDemo.csdproj.user
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\Compact Framework\Form1.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\Compact Framework\Form1.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\Compact Framework\AssemblyInfo.cs
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Zoom_Scroll
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Zoom_Scroll\Zoom_Direction.cs
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Utilities
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Utilities\SourceUtils.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Utilities\DemoTreeNode.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Zoom_Scroll\Zoom_Scroll.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Zoom_Scroll\Zoom_Scroll.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Zoom_Scroll\Zoom_Pen.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Zoom_Scroll\Zoom_Pen.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Zoom_Scroll\Zoom_MinPix.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Zoom_Scroll\Zoom_MinPix.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Zoom_Scroll\Zoom_Direction.resx
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\SeriesAnimate.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\SeriesAnimate.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Rotate.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Rotate.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\PieTool.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\PieTool.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Nearest.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Nearest.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\MarksTip.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\MarksTip.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Image.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Image.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\GanttTool.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\GanttTool.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\DrawLineDragged.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\DrawLineDragged.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\DrawLine.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\DrawLine.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\DragPoint.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\DragPoint.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\DragMark.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\DragMark.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Cursor_Sync.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Cursor_Sync.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Cursor_Prog.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Cursor_Prog.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Cursor.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Cursor.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\ColorLine.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\ColorLine.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\ColorBand_Transparent.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\ColorBand_Transparent.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\ColorBand.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\ColorBand.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\AxisArrow.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\AxisArrow.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Annotation_Click.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Annotation_Click.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Annotation.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Annotation.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\3DTranspose.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\3DTranspose.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\TeeChartExamples.ico
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\TeeChart Examples.sln
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\TeeChart Examples.csproj.user
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\WindRose.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\WindRose.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\WaterFall.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\WaterFall.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Volume_Origin.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Volume_Origin.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Volume.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Volume.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\TriSurface_Hiding.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\TriSurface_Hiding.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\TriSurface.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\TriSurface.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Tower.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Tower.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\AssemblyInfo.cs
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Axis
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Axis\Axis_Behind.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Axis\Axis_Behind.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Axis\Axis_Custom.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Axis\Axis_Custom.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Axis\Axis_Millisecond.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Axis\Axis_Millisecond.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Axis\Axis_TitleVisible.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Axis\Axis_TitleVisible.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Axis\Exponent.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Axis\Exponent.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Axis\LabelAlign.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Axis\LabelAlign.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Axis\MinorGrid.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Axis\MinorGrid.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Axis\MultiScroll.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Axis\MultiScroll.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Axis\Offsets.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Axis\Offsets.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Axis\OpaqueZone.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Axis\OpaqueZone.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Axis\ZPosition.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Axis\ZPosition.resx
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\bin
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\bin\ExecutableDemo
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\bin\ExecutableDemo\AxInterop.SHDocVw.dll
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\bin\ExecutableDemo\Interop.SHDocVw.dll
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\bin\ExecutableDemo\TeeChartNetExamples.exe
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\bin\Release
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\bin\Release\AxInterop.SHDocVw.dll
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\bin\Release\Interop.SHDocVw.dll
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\bin\Release\TeeChartNetExamples.exe
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Canvas
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Canvas\Canvas_DotPen.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Canvas\Canvas_DotPen.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Canvas\Canvas_GradMiddle.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Canvas\Canvas_GradMiddle.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Canvas\Canvas_OrthoAngle.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Canvas\Canvas_OrthoAngle.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Canvas\Canvas_PyramidTrunc.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Canvas\Canvas_PyramidTrunc.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Canvas\Canvas_RotCenter.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Canvas\Canvas_RotCenter.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Canvas\Canvas_Transp.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Canvas\Canvas_Transp.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Canvas\RichText_Drawing.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Canvas\RichText_Drawing.resx
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Components
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Components\ChartListBox.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Components\ChartListBox.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Components\Chart_Gallery.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Components\Chart_Gallery.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Components\Gallery_Panel.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Components\Gallery_Panel.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Components\TCommander_Demo.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Components\TCommander_Demo.resx
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\DataSource
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\DataSource\DataConnect.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\DataSource\DataConnect.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\DataSource\DatasetEditor.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\DataSource\DatasetEditor.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\DataSource\DataTable.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\DataSource\DataTable.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\DataSource\DateTimeData.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\DataSource\DateTimeData.resx
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Export
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Export\Bitmap.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Export\Bitmap.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Export\Excel.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Export\Excel.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Export\GIF.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Export\GIF.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Export\HTML.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Export\HTML.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Export\JPEG.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Export\JPEG.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Export\Metafile.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Export\Metafile.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Export\PNG.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Export\PNG.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Export\Template.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Export\Template.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Export\Text.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Export\Text.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Export\TIFF.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Export\TIFF.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Export\XML.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Export\XML.resx
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\Add.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\Add.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\Average.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\Average.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\Count.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\Count.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\CrossPoint.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\CrossPoint.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\Cumulative.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\Cumulative.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\CurveFitting.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\CustomY.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\CustomY.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\Divide.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\Divide.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\ExpAve.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\ExpAve.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\ExpMovAve.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\ExpMovAve.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\Function_SPC.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\Function_SPC.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\Momentum.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\Momentum.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\MomentumDiv.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\MomentumDiv.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\Multiply.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\Multiply.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\RMS.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\RMS.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\Smoothing.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\Smoothing.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\StdDev.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\StdDev.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\Subtract.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Functions\Subtract.resx
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Import
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Import\Text.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Import\Text.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Import\WebSource.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Import\WebSource.resx
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Legend
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Legend\Legend_AddText.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Legend\Legend_AddText.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Legend\Legend_CheckBox.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Legend\Legend_CheckBox.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Legend\Legend_CustomPos.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Legend\Legend_CustomPos.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Legend\Legend_FontColor.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Legend\Legend_FontColor.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Legend\Legend_Multi.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Legend\Legend_Multi.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Legend\Legend_Scroll.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Legend\Legend_Scroll.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Legend\Legend_Series.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Legend\Legend_Series.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Legend\Legend_TextStyle.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Legend\Legend_TextStyle.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Legend\Legend_VertSpac.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Legend\Legend_VertSpac.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Legend\Legend_Widths.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Legend\Legend_Widths.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Main.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Main.resx
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Marks
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Marks\Angle.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Marks\Angle.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Marks\DrawEvery.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Marks\DrawEvery.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Marks\Multi.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Marks\Multi.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Marks\Shadow.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Marks\Shadow.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Marks\Style.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Marks\Style.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Marks\XYStyle.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Marks\XYStyle.resx
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Other
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Other\Base.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Other\Base.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Other\BaseNoChart.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Other\BaseNoChart.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Other\Basic_Features.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Other\Basic_Features.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Other\Clipboard_Single.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Other\Clipboard_Single.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Other\Customers.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Other\Customers.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Other\Order_Info.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Other\Order_Info.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Other\Translations.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Other\Translations.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Other\Welcome.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Other\Welcome.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Other\Welcome_All.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Other\Welcome_All.resx
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Print
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Print\PreviewDialog.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Print\PreviewDialog.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Area.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Area.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Area_Gradient.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Area_Gradient.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Area_Origin.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Area_Origin.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Area_Transparency.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Area_Transparency.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Arrow.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Arrow.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Bar.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Bar.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Bar3D.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Bar3D.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\BarJoin.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\BarJoin.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Bar_Cone.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Bar_Cone.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Bar_Gradient.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Bar_Gradient.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Bar_GroupStack.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Bar_GroupStack.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Bar_Image.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Bar_Image.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Bar_NegativeStacked.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Bar_NegativeStacked.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Bar_SideAll.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Bar_SideAll.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Bezier.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Bezier.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\BoxPlot.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\BoxPlot.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Bubble.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Bubble.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Calendar.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Calendar.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Candle.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Candle.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Candle_CustomColors.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Candle_CustomColors.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Candle_GetPointerStyle.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Candle_GetPointerStyle.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Candle_NoWeekends.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Candle_NoWeekends.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Clock.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Clock.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\ColorGrid.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\ColorGrid.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Contour.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Contour.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Contour_CustLev.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Contour_CustLev.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Contour_Palette.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Contour_Palette.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Contour_View2D.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Contour_View2D.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\DeltaPoint.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\DeltaPoint.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Donut.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Donut.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Error.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Error.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\ErrorBar_Negative.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\ErrorBar_Negative.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Fastline.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Fastline.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Fastline_DrawAll.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Fastline_DrawAll.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Funnel.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Funnel.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Gantt.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Gantt.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\HighLow.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\HighLow.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Histogram.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Histogram.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Histogram_Transparency.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Histogram_Transparency.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\HorizBar.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\HorizBar.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\HorizLine.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\HorizLine.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Line.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Line.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Line_Clickable.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Line_Clickable.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Line_ColorEach.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Line_ColorEach.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Line_Outline.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Line_Outline.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Line_Patterns.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Line_Patterns.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Line_Stack.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Line_Stack.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\MyPoint.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\MyPoint.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Pie.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Pie.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Pie_Multi.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Pie_Multi.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Pie_Semi.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Pie_Semi.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Pie_Shadow.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Pie_Shadow.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Point.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Point.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Point3D.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Point3D.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Point3D_Event.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Point3D_Event.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\PointAndFigure.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\PointAndFigure.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Polar.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Polar.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Polar_ClockWise.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Polar_ClockWise.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Polar_LabelsInside.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Polar_LabelsInside.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Polar_Transparency.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Polar_Transparency.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Pyramid.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Pyramid.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Radar.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Radar.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Realtime.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Realtime.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Shape.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Shape.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Shape_Image.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Shape_Image.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Shape_VertAlign.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Shape_VertAlign.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Smith.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Smith.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Surface.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Surface.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Surface_Irregular.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Surface_Irregular.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Surface_XYZFloat.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Series\Surface_XYZFloat.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\ReadmePocket.txt
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Docs\TeeChartNET1.chm
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\Sample data
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Sample data\TeeChart.mdb
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Sample data\readme.txt
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Utils\Readme.txt
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChart.Pocket.dll
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Docs\Steema.TeeChart_COL.HxT
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Docs\Steema.TeeChart_COL.HxC
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Docs\Steema.TeeChart.HxS
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Utils\TeeGofer_H2reg.exe
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Utils\Interop.MSHelpServices.dll
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChart.Languages.xml
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChart.Languages.dll
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Docs\TeeChart for .Net Tutorials.chm
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\Docs\images
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Docs\images\TChart.ico
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChart.xml
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Support.txt
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Release.txt
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChart.dll
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\License.txt
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\bin\ExecutableDemo\TeeChart.Languages.dll
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\bin\ExecutableDemo\TeeChart.Languages.xml
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\bin\ExecutableDemo\TeeChart.xml
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\bin\ExecutableDemo\TeeChart.dll
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\bin\Release\TeeChart.Languages.xml
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\bin\Release\TeeChart.Languages.dll
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\bin\Release\TeeChart.xml
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\bin\Release\TeeChart.dll
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\DemoHome.htm
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\images
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\images\TeeChartNET.png
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\Readme.txt
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\Steema.css
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\BACKUP
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\Readme.txt
    Backup Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\BACKUP\Readme.txt
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\ASPStream
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\ASPStream\ASPStream.csproj
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\ASPStream\ASPStream.csproj.webinfo
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\ASPStream\ASPStream.sln
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\ASPStream\ASPStream.vsdisco
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\ASPStream\AssemblyInfo.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\ASPStream\Global.asax
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\ASPStream\Global.asax.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\ASPStream\Global.asax.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\ASPStream\SeriesTypes.aspx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\ASPStream\SeriesTypes.aspx.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\ASPStream\SeriesTypes.aspx.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\ASPStream\ShowSeries.aspx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\ASPStream\ShowSeries.aspx.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\ASPStream\ShowSeries.aspx.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\ASPStream\Web.config
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\ASPStream\bin
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\ASPStream\bin\ASPStream.dll
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\ASPStream\images
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\ASPStream\images\TeeChartNET.png
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\WebForm
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\WebForm\AssemblyInfo.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\WebForm\GetChart.aspx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\WebForm\GetChart.aspx.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\WebForm\GetChart.aspx.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\WebForm\Global.asax
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\WebForm\Global.asax.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\WebForm\Global.asax.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\WebForm\Web.config
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\WebForm\WebForm.csproj
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\WebForm\WebForm.csproj.webinfo
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\WebForm\WebForm.sln
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\WebForm\WebForm.vsdisco
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\WebForm\WebForm1.aspx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\WebForm\WebForm1.aspx.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\WebForm\WebForm1.aspx.resx
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\WebForm\bin
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\WebForm\bin\WebForm.dll
    Made Dir: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\WebForm\images
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\WebForm\images\TeeChartNET.png
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\ASPStream\bin\TeeChart.xml
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\WebForm\bin\TeeChart.xml
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\ASPStream\bin\TeeChart.dll
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\WebForm\bin\TeeChart.dll
    Made Dir: C:\Documents and Settings\sirhc\Start Menu\Programs\Steema TeeChart for .NET v1
    Shell Link: C:\Documents and Settings\sirhc\Start Menu\Programs\Steema TeeChart for .NET v1\ASP Server examples.lnk
    Shell Link: C:\Documents and Settings\sirhc\Start Menu\Programs\Steema TeeChart for .NET v1\Feature demo.lnk
    Shell Link: C:\Documents and Settings\sirhc\Start Menu\Programs\Steema TeeChart for .NET v1\TeeChart for .Net Tutorials.lnk
    Shell Link: C:\Documents and Settings\sirhc\Start Menu\Programs\Steema TeeChart for .NET v1\TeeChart for .NET Help.lnk
    Shell Link: C:\Documents and Settings\sirhc\Start Menu\Programs\Steema TeeChart for .NET v1\Welcome ReadMe.lnk
    Shell Link: C:\Documents and Settings\sirhc\Start Menu\Programs\Steema TeeChart for .NET v1\Examples.lnk
    RegDB Key: Software\Steema Software\TeeChart.NET
    RegDB Val: /TeeChartForNET
    RegDB Name: VirtualShare
    RegDB Root: 1
    RegDB Old: /TeeChartForNET
    RegDB Root: 2
    RegDB Val: C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET
    RegDB Name: ShareFolder
    RegDB Root: 2
    RegDB Old: C:\Program Files\Steema Software\TeeChart for .NET v1 Evaluation\TeeChartForNET
    RegDB Root: 1
    RegDB Key: Software\Microsoft\.NETFramework\AssemblyFolders\TeeChart
    RegDB Root: 2
    RegDB Key: Software\Steema Software\.NET demo
    RegDB Val: ..\..\
    RegDB Name: Demo Path
    RegDB Root: 1
    RegDB Old: ..\..\
    RegDB Key: Software\Microsoft\Windows\HTML Help
    RegDB Val: C:\Program Files\Steema Software\TeeChart for .NET v1\Docs
    RegDB Name: TeeChartNET1.chm
    RegDB Root: 2
    RegDB Old: C:\Program Files\Steema Software\TeeChart for .NET v1 Evaluation\Docs
    Execute Program: C:\PROGRA~1\STEEMA~1\TEECHA~2.NET\Utils\TeeGofer_H2reg.exe /u /f:Steema.TeeChart /i:MS.VSCC/MS.VSCC.2003 /n:Steema.TeeChart /p:"C:\PROGRA~1\STEEMA~1\TEECHA~2.NET\Docs"
    RegDB Name: DisplayVersion
    RegDB Root: 2
    RegDB Val: http://www.steema.com
    RegDB Name: HelpLink
    RegDB Root: 2
    RegDB Val: +34 972 21 87 97
    RegDB Name: HelpTelephone
    RegDB Root: 2
    RegDB Val: Steema Softtware SL
    RegDB Name: Publisher
    RegDB Root: 2
    RegDB Name: URLInfoAbout
    RegDB Root: 2
    RegDB Val: info@steema.com
    RegDB Name: Contact
    RegDB Root: 2
    RegDB Name: Comments
    RegDB Root: 2
    RegDB Val: C:\PROGRA~1\STEEMA~1\TEECHA~2.NET\Docs\images\TChart.ico,-0
    RegDB Name: DisplayIcon
    RegDB Root: 2
    User Rights: Admin
    *** Installation Started 12/29/2003 7:31 ***
    Source: C:\DOCUME~1\sirhc\LOCALS~1\Temp\GLB28DD.tmp
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\UNWISE.EXE
    RegDB Root: 2
    RegDB Old: TeeChart for .NET v1
    RegDB Root: 2
    RegDB Old: C:\PROGRA~1\STEEMA~1\TEECHA~2.NET\UNWISE.EXE C:\PROGRA~1\STEEMA~1\TEECHA~2.NET\INSTALL.LOG
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Zoom_Scroll\Zoom_Scroll.cs
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Zoom_Scroll\Zoom_Pen.resx
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Zoom_Scroll\Zoom_Pen.cs
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Zoom_Scroll\Zoom_MinPix.resx
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Zoom_Scroll\Zoom_MinPix.cs
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Zoom_Scroll\Zoom_Direction.resx
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Zoom_Scroll\Zoom_Direction.cs
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Utilities\SourceUtils.cs
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Utilities\DemoTreeNode.cs
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\SeriesAnimate.resx
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\SeriesAnimate.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\RotateOutline.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\RotateOutline.cs
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Rotate.resx
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Rotate.cs
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\PieTool.resx
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\PieTool.cs
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Nearest.resx
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Nearest.cs
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\MarksTip.resx
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\MarksTip.cs
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Image.resx
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Image.cs
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\GanttTool.resx
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\GanttTool.cs
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\DrawLineDragged.resx
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\DrawLineDragged.cs
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\DrawLine.resx
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\DrawLine.cs
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\DragPoint.resx
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\DragPoint.cs
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\DragMark.resx
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\DragMark.cs
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Cursor_Sync.resx
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Cursor_Sync.cs
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Cursor_Prog.resx
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Cursor_Prog.cs
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Cursor.resx
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Cursor.cs
    Backup Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\BACKUP\Cursor.cs
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\ColorLine.resx
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\ColorLine.cs
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\ColorBand_Transparent.resx
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\ColorBand_Transparent.cs
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\ColorBand.resx
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\ColorBand.cs
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\AxisArrow.resx
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\AxisArrow.cs
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Annotation_Click.resx
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Annotation_Click.cs
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\AnnotationCallout.resx
    File Copy: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\AnnotationCallout.cs
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Annotation.resx
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\Annotation.cs
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\3DTranspose.resx
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\Tools\3DTranspose.cs
    File Overwrite: C:\Program Files\Steema Software\TeeChart for .NET v1\Examples\DemoProject\TeeChartExamples.ico
Thank you!
http://groups.google.com
http://codenewsfast.com/
