Unhandled Exception in Examples
MTB
Post by MTB » Mon Jan 26, 2004 5:45 pm
I installed the latest build for VS.NET 2002, and opened TeeChart for .NET Examples. I clicked on New Features | Chart | Canvas | Rotated Ellipses, and I encountered the following exception.
************** Exception Text **************
System.OverflowException: Overflow error.
at System.Drawing.Graphics.FillPolygon(Brush brush, Point[] points, FillMode fillMode)
at System.Drawing.Graphics.FillPolygon(Brush brush, Point[] points)
at Steema.TeeChart.Drawing.Graphics3DGdiPlus.Polygon(Point[] p)
at Steema.TeeChart.Drawing.Graphics3D.Polygon(Int32 z, Point[] p)
at Steema.TeeChart.Drawing.Graphics3D.Ellipse(Int32 left, Int32 top, Int32 right, Int32 bottom, Int32 z, Double angle)
at Steema.TeeChart.Samples.Canvas_RotatedEllipse.tChart1_AfterDraw(Object sender, Graphics3D g)
at Steema.TeeChart.TChart.Steema.TeeChart.IChart.DoAfterDraw()
at Steema.TeeChart.TChart.Draw(Graphics g)
at Steema.TeeChart.TChart.OnPaint(PaintEventArgs pe)
at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
at System.Windows.Forms.Control.WmPaint(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.3300.0
Win32 Version: 1.0.3705.288
CodeBase: file:///c:/winnt/microsoft.net/framework/v1.0.3705/mscorlib.dll
TeeChartNetExamples
Assembly Version: 2.0.1468.24327
Win32 Version: 2.0.1468.24327
CodeBase: file:///C:/Program%20Files/Steema%20Software/TeeChart%20for%20.NET%20v1/Examples/DemoProject/bin/ExecutableDemo/TeeChartNetExamples.exe
CodeBase: file:///c:/winnt/assembly/gac/system.windows.forms/1.0.3300.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/winnt/assembly/gac/system/1.0.3300.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/winnt/assembly/gac/system.drawing/1.0.3300.0__b03f5f7f11d50a3a/system.drawing.dll
AxInterop.SHDocVw
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///C:/Program%20Files/Steema%20Software/TeeChart%20for%20.NET%20v1/Examples/DemoProject/bin/ExecutableDemo/AxInterop.SHDocVw.DLL
Interop.SHDocVw
CodeBase: file:///C:/Program%20Files/Steema%20Software/TeeChart%20for%20.NET%20v1/Examples/DemoProject/bin/ExecutableDemo/Interop.SHDocVw.DLL
Accessibility
Win32 Version: 1.0.3705.0
CodeBase: file:///c:/winnt/assembly/gac/accessibility/1.0.3300.0__b03f5f7f11d50a3a/accessibility.dll
TeeChart
Assembly Version: 1.0.1452.42972
Win32 Version: 1.0.1452.42972
CodeBase: file:///C:/Program%20Files/Steema%20Software/TeeChart%20for%20.NET%20v1/Examples/DemoProject/bin/ExecutableDemo/TeeChart.DLL
System.Web
CodeBase: file:///c:/winnt/assembly/gac/system.web/1.0.3300.0__b03f5f7f11d50a3a/system.web.dll
System.Design
CodeBase: file:///c:/winnt/assembly/gac/system.design/1.0.3300.0__b03f5f7f11d50a3a/system.design.dll
System
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/winnt/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
Post by Marc » Tue Jan 27, 2004 6:24 pm
I can't reproduce that straight-off here, I've tried it with the VS2002 and VS2003 compiled versions. I assume the other examples work OK?
I can't see an obvious cause for the problem though the error log does show that system.dll from Framework 1.1 is being accessed, that may be worth following up on. Reflecting here shows that the example project was compiled with dependency of v1.0.3300.0 (VS2002 Framework v1.0.3705 I believe).
