Using DragPoint in a Gantt Chart
TonyHunt
Post by TonyHunt » Mon Jul 13, 2009 12:31 pm
I am investigating Using DragPoint in a Gantt Chart on the Y axis. This works well but I would like to be able so enable a 'SnapTo' or Step feature rather than the smooth linear result I am getting from the DragPoint at the moment.
I have seen the 'Desired Increment' on the Left Axis but regrettably this doesn't appear to do what I want.
Any suggestions for a work around and any samples of using the Gantt chart in more depth would be much appreciated.
Best Wishes
Tony Hunt
Re: Using DragPoint in a Gantt Chart
Post by Yeray » Tue Jul 14, 2009 8:26 am
Hi Tony,
There is the Gantt Drag tool that allows dragging but without allowing you to set the tolerance you wish.
Here you have an example of how you could do something like what you requested without any tool, directly using OnMouseDown, OnMouseUp and OnMouseMove events:
  Form1: TForm1;
  DraggingIndex, DraggingTolerance, StartX: Integer;
  OldStartValue, OldEndValue: Double;
  series1: TGanttSeries;
implementation
{$R *.dfm}
  DraggingIndex := -1;
  DraggingIndex := Series1.Clicked(X, Y);
  if (DraggingIndex>-1) then
    StartX := X;
    OldStartValue := series1.StartValues.Items[DraggingIndex];
    OldEndValue := series1.EndValues.Items[DraggingIndex];
  Y: Integer);
var movedValues: double;
  if (Series1.Clicked(X, Y) <> -1) then
    Chart1.Cursor := crHandPoint;
    Chart1.CancelMouse := True;
    movedValues := Abs(Chart1.Axes.Bottom.CalcPosPoint(X))-Abs(Chart1.Axes.Bottom.CalcPosPoint(StartX));
    series1.StartValues.Items[DraggingIndex] := OldStartValue + round(movedValues / DraggingTolerance)*DraggingTolerance;
    series1.EndValues.Items[DraggingIndex] := OldEndValue + round(movedValues / DraggingTolerance)*DraggingTolerance;
    Chart1.Title.Text.Text := floattostr(X-StartX);
    Chart1.Draw;
  Chart1.View3D := false;
  Chart1.AllowZoom := false;
  series1 := TGanttSeries.Create(self);
  Chart1.AddSeries(series1);
  series1.FillSampleValues(6);
  DraggingTolerance := 5;
TonyHunt
Post by TonyHunt » Tue Jul 14, 2009 11:25 am
Thank you very much, that gave me a good insight into several other things as well.
Tony
