Setting Grid.Visible is neither saved nor loaded
mikebo
Post by mikebo » Fri Jun 12, 2009 11:29 am
i using delphi 2007 and TeeChart 8.05
I am running an application, which allows the user to customize the chart, saving it and reloading it.
It seems that the information "show grid lines" is not be saved - or loaded?
What to do?
Mike
Re: Setting Grid.Visible is neither saved nor loaded
Post by Yeray » Fri Jun 12, 2009 1:35 pm
Hi Mike,
Could you please send us a simple example project we can run as-is here to reproduce the problem here? I've tested with the following code and everything seems to work as expected:
uses series, teestore;
  Chart1.AddSeries(TLineSeries.Create(self));
  Chart1[0].FillSampleValues(25);
  Chart1.Axes.Bottom.Grid.Visible := false;
  SaveChartToFile(Chart1, 'C:\test.tee',true,true);
  Chart1.ClearChart;
var tmpChart: TCustomChart;
  tmpChart := TChart.Create(self);
  LoadChartFromFile(tmpChart, 'C:\test.tee');
  Chart1 := tmpChart as TChart;
  Chart1.Parent := Self;
Note that you can now attach your files directly to this forums.
mikebo
Post by mikebo » Sun Jun 14, 2009 10:02 am
thank you. I found the error. It was my mistake.
best regards
mike
