Class TBarSeries Not Found
GDEW
Post by GDEW » Tue May 26, 2009 6:23 pm
System: Rad Studio 2007
TeeChart: Standard 8.05
Using TChart for simple barchart test. Compile, build works fine. Get error when executing (Class TBarSeries Not Found). The support base suggests the inclusion of TeeEditPRO in the uses section. The standard edition does not have the TeeEditPRO component? How do I get the charts to work? My Delphi 2005 (on another PC) still works fine.
Post by Yeray » Wed May 27, 2009 7:47 am
Hi GDEW,
I'll test this but in the meanwhile, could you verify that your IDE's search and library paths don't contain any reference to any previous TeeChart installation?
GDEW
Location / paths of TeeChart 8.05
Post by GDEW » Wed May 27, 2009 10:08 am
Installed Components / Package:
DclTee811.bpl (dated 22/05/2009)
Path (standard as per installation):
C:\Program Files\Steema Software\TeeChart Standard 8 for Delphi 2007\Delphi11\Bin
Checked Search and Library Paths:
Search Path: Blank
Library Path: C:\Program Files\Steema Software\TeeChart Standard 8 for Delphi 2007\Delphi11\Lib
Post by Narcís » Wed May 27, 2009 11:41 am
If you can't use TeeEditPro you can manually register series using RegisterTeeSeries or RegisterClass as described on this thread:
http://www.teechart.net/support/viewtopic.php?t=6610
Hope this helps!
GDEW
Class TBarSeries not Found
Post by GDEW » Thu May 28, 2009 1:04 am
Tried that, no success:
Simple form:
unit Unit2;
interface
uses
Dialogs, Series, TeEngine, ExtCtrls, TeeProcs, Chart;
type
TForm2 = class(TForm)
Chart1: TChart;
private
{ Private declarations }
public
{ Public declarations }
Form2: TForm2;
implementation
{$R *.dfm}
RegisterClass(TBarSeries);
end.
The designer has a simple TChart with a few manual points as data (3d Barchart).
As I said, compiles OK, but will not run. I also tried RegisterTeeSeries, no success. RegisterTeeTool is not in the Standard edition.
Can we try something else?
GDEW
Class not Registered
Post by GDEW » Thu May 28, 2009 1:22 am
Solved the problem!
RegisterClass(TBarSeries) does work, as long as the Chart is not on the main form. I put it there for testing, but single stepping the code I realised that the Create event takes place after the error message (meaning that the chart is already being loaded). I moved the chart to a second form, kept the RegisterClass on the create event of the main form, then called the second form with the graph. That appears to be working fine.
There is thus a problem with the Run-Time library loading the class registrations. Maybe you can check on this for your next upgrade?
Thanks, all ok for now.
Post by Narcís » Thu May 28, 2009 10:46 am
Hi GDEW,
Thanks for your feedback. Would you be so kind to send us a simple example project we can run "as-is" where the error occurs so that we can look for alternatives and enhancing this if possible?
