CloneChartSeries and 3D PieSeries
Al1
Post by Al1 » Wed May 20, 2009 12:20 pm
Hey,
I have found another funny bug...
You can find the file Project1.zip I have uploaded today.
When I clone a TPieSeries in a 3D TChart, the depth of each slices is inverted! Another clone to a TQRChart produce the same artifact. But (even better) when I close the third form (containing the TQRChart) the second TChart is now correctly displayed. I can open another time the third form to have a good copy of the first graph.
Any idea for a workaround?
Alain
Al1
Post by Al1 » Wed May 20, 2009 12:40 pm
I have found a way:
  CloneChartSeries(Series1).ParentChart := Form3.QRChart1.Chart;
  if Chart1.View3D
  then
    Form3.QRChart1.Chart.FreeAllSeries(nil);
After cloning the TPieSeries, if the 3DView is active then I free it and clone it a second time.
Ask me if you have a better solution!
Post by Yeray » Wed May 20, 2009 2:36 pm
Hi Alain,
Yes you are right. It seems that the pie series aren't cloned fine or something. I've added this to the wish list to be revised for next releases (TV52014170).
I've tried forcing a chart repaint but it has no effect, so you workaround seems to be the best.
