ValueColor
Al1
ValueColor
Post by Al1 » Tue May 12, 2009 5:15 pm
Hey,
Since TeeSaveToPDFFile is not valid with Delphi 2009 (and TeeChart Pro 8.04), I try to export my graphs from QuickReport 5 with Gnostice Technologies...
I have installed QRChart (which is a little hard)! After that, I have created a form containing a QuickRep component and a QRChart. Her is my code:
procedure TForm1.SpeedButtonPDFClick(Sender: TObject);
  if SaveDialog1.Execute
  then
//    TeeSaveToPDFFile(Chart1, SaveDialog1.FileName, Chart1.Width, Chart1.Height);
    Screen.Cursor := crHourGlass;
    Form2 := TForm2.Create(nil);
    try
      Form2.QRChart1.SetChart(Chart1);
//      Form2.QuickRep1.PreviewModal;
      Form2.gtPDFEngine1.FileName := SaveDialog1.FileName;
      Form2.gtQRExportInterface1.RenderDocument(Form2.QuickRep1, False);
    finally
      Form2.Release;
      Screen.Cursor := crDefault;
Chart1 has only a PieSeries. Everything is perfectly working with this code, excepted a strange problem with the value colors.
The values are inserted with the AddPie method and only AValue and ALabel parameters (not AColor in order to use the default color).
Graphs with 1 or 2 values are ok, but another with 9 values is not correctly copied: colors became (yellow, blue, white, gray, ...) instead of (red, green, yellow, blue, ...)!
This issue is not coming from the PDF export because it occurs also in a preview of the report!
Is it a bug?
Alain
Post by Yeray » Wed May 13, 2009 7:52 am
Hi Alain,
I've tested it and I see the preview with the good colors (dark blue, orange, red, soft blue, marine blue, dark green,...) of the opera palette.
I used this code and a teecommander to see the export preview.
  Chart1.AddSeries(TPieSeries.Create(self));
  with (Chart1[0] as TPieSeries) do
    AddPie(10,'one');
    AddPie(19,'two');
    AddPie(20,'three');
    AddPie(18,'four');
    AddPie(16,'five');
    AddPie(25,'six');
Please, could you send us a simple example project we can run "as-is" to reproduce the problem here?
Al1
ValueColor
Post by Al1 » Wed May 13, 2009 10:11 am
I have uploaded a simple project which reproduce the problem...
A Form with a Chart having a PieSeries and a SpeedButton to clone the graph in another Chart to anaother Form.
ValueColors are modified!
Alain
Post by Yeray » Wed May 13, 2009 11:33 am
It seems that having pie series with OtherSlice.Style := poBelowPercent and you clone the series, the colors seem to be copied in different indexes.
Easy to reproduce with this:
uses series;
var Series1: TPieSeries;
  Series1 := TPieSeries.Create(self);
  Chart1.AddSeries(Series1);
  with Series1 do
    AddPie(30, 'Part1');
    AddPie(30, 'Part2');
    AddPie(20, 'Part3');
    AddPie(10, 'Part4');
    OtherSlice.Style := poBelowPercent;
    OtherSlice.Value := 20;
var Series2: TPieSeries;
  Series2 := TPieSEries(CloneChartSeries(Series1, Chart2));
  Chart2.AddSeries(Series2);
  with Series2 do
    OtherSlice.Style := Series1.OtherSlice.Style;
    OtherSlice.Value := Series1.OtherSlice.Value;
I've added this to the wish list to be fixed in future releases (TV52014152)
Al1
Post by Al1 » Wed May 13, 2009 1:16 pm
Thank you for your help!
This code is ok:
procedure TForm1.SpeedButton1Click(Sender: TObject);
  try
    Series1.OtherSlice.Style := poNone;
    CloneChartSeries(Series1, Chart1).ParentChart := Form2.Chart1;
    Series1.OtherSlice.Style := poBelowPercent;
    TPieSeries(Form2.Chart1[0]).OtherSlice.Style := poBelowPercent;
    Form2.ShowModal;
  finally
    Form2.Release;
Best regards,
Alain
