Define legend color for a series?
Windwalker
Post by Windwalker » Tue Apr 28, 2009 9:24 am
I have a chart with TBar-Series.
Since the look of the color gradient on my bars, SeriesColor is not the color I would like to represent the respective series in the legend.
Instead I would like to have Gradient.MidColor as the color by which the series is represented in the legend.
Is there a way to achieve this?
Thanks a lot!
BTW: I am running TeeChart 8.04 Pro ond Delphi VCL 2006.
Post by Yeray » Tue Apr 28, 2009 10:09 am
Hi Windwalker,
I think you should do something similar to the example at All features/Miscellaneous/Legend/Symbol OnDraw in the new features demo available at TeeChart's program group.
I hope this helps
Windwalker
Post by Windwalker » Thu Apr 30, 2009 7:07 am
Thanks for your hint!
Could you please give me some advise, on how I can draw a rectangle with my intended color and then place this rectangle by the use of StretchDraw in the legend?
I tried to do it like this, but StrechtDraw does not accept my Rect-Object.
procedure TForm_DTM_UmsatzStat.LegendDraw(Sender: TObject; Series:TChartSeries;
                            ValueIndex:Integer; R:TRect);
  symbol : TRect;
  Brush.Style := bsSolid;
  Brush.Color := clRed;                          // or any other color
  symbol := Rect(R.Left, R.Top, R.Right, R.Bottom);
  Chart_Umsatz.Canvas.StretchDraw(R, symbol);
Thanks again!
Windwalker
Post by Windwalker » Thu Apr 30, 2009 7:30 am
I finally got it work.
Thanks anyway!
