Extra legend tool
stsl
Extra legend tool
Post by stsl » Mon Apr 06, 2009 11:26 am
How is it possible to add a custom symbol in an Extra legend tool ?
I use LegendStyle := lsGroups and i would like to draw a colored square between the check box and the text of the group name.
I didn't find when the Symbol.OnDraw event is fired.
Best regards
Post by Yeray » Mon Apr 06, 2009 2:20 pm
Hi stsl,
Yes, I'm afraid that there is no event for customizing the ExtraLegendTool symbol. But you always can draw custom rectangles directly to the canvas at OnAfterDraw event or where you are customizing your tool.
stsl
Post by stsl » Mon Apr 06, 2009 2:30 pm
Are you sure that it's only on the extra legend tool ?
With the normal legend, it's not possible to have symbols when we use lsGroups.
I don't know why i purchased TeeChart because i have to draw myself everything.
stsl
Post by stsl » Mon Apr 06, 2009 2:52 pm
Your are wrong, it's also possible to add rectangle in an extralegend but only when we are in lsSeries mode.
Please, this behaviour is very important for me and (and very urgent) and i have no time to find a workaround for this bug (for me, it's a bug,
and when i use TeeChart, i spend 60% of my time to bypass bugs and strange things).
Post by Yeray » Mon Apr 06, 2009 3:36 pm
Hi stsl,
Excuse me if I haven't been enough clear. I meant that the event OnDraw for symbol legend only seems to work for the normal legend, not for this tool. And I've added it to the wish list to be fixed asap (TV52014060).
So, for the normal legend it would be easy to draw the custom symbols with this event (you can see the demo at All Features/Miscellaneous/Legend/Symbol OnDraw).
Note that for a legend where each item represents a point (with a concrete color) or a series (with a concrete color) it's easy to determine the symbol to draw. But having a group of series, there is not a clear unique solution (or we haven't determined yet) on which symbol has to be drawn.
stsl
Post by stsl » Mon Apr 06, 2009 4:37 pm
I have to use an extra legend tool and not a normal legend (see my different post about the legend and the solution that you suggested for me in the past).
Note :
I know that you can't determine wich color we have to use for a group but i know that i would like to see in my legend (not a color in my case...)
I am afraid about your "ASAP" criteria. I am waiting a patch for a very important bug since 2005.
Post by Yeray » Tue Apr 07, 2009 8:21 am
Hi stsl,
stsl wrote:I am waiting a patch for a very important bug since 2005.
Could you please tell us the number of the bug or the forum thread where this bug was discussed and we'll see its state?
We understand that, in the customer side, some of you have important problems that demand immediate intervention, but without any doubt, you'll understand that we also have to value other aspects such as the number of customers affected, if there is a workaround or not, the percentage of the component that is affected, the relation cost/benefit of the implementation,...
stsl
Post by stsl » Tue Apr 07, 2009 11:04 am
Summary of my post, about a very critical bug (null values are different than 0 values) :
Posted: 02 Nov 2005 18:35 Post subject: Functions, period range and data leak
and your response
Posted: 07 Apr 2008 10:13 Post subject: Reply with quote
Hi stsl,
I've added the feature request to the wish list (TV52012945) to be reviewed and, if possible, enhanced in further releases. This may be quite a sensible issue as implementing it as you request may break existing clients code.
Also notice that we don't provide support for changes to the source code but you are free to implement the necessary customizations to fit your needs.
_________________
Best Regards
Yeray Alonso
Best regards
Post by Yeray » Tue Apr 07, 2009 11:49 am
Hi stsl,
Please, see my answer in the according forum thread.
stsl
Post by stsl » Thu Apr 30, 2009 8:05 am
When did you plan to fix this bug ? I hope in the 8.05 release.....
Post by Narcís » Thu Apr 30, 2009 10:27 am
Hi stsl,
Here's an update on the status of the issues discussed on this thread:
TV52014060: I've checked this already works fine here using something as the code below. Can you please check if this works fine for you?
  Series1.FillSampleValues();
  ChartTool1.Legend.Symbol.OnDraw:=LegendDraw;
procedure TForm1.LegendDraw(Sender: TObject; Series:TChartSeries;
                            ValueIndex:Integer; R:TRect);
var Flag : TBitmap;
  Flag:=TBitmap.Create;  // create flag bitmap
  try
    Dec(R.Top,3);
    Inc(R.Bottom,3);
    if ValueIndex mod 2 = 0 then
      Flag.LoadFromFile('C:\temp\TeeCopy.bmp')
      Flag.LoadFromFile('C:\temp\TeeDepth.bmp');
    with Chart1.Canvas do
      StretchDraw(R,Flag);  // draw image to legend
      // draw border
      if Chart1.Legend.Symbol.Pen.Visible then
        Brush.Style:=bsClear;
        AssignVisiblePen(Chart1.Legend.Symbol.Pen);
        Rectangle(R,0);
  finally
    Flag.Free;  // destroy bitmap
TV52012945: We don't consider this being a bug but a feature request, which is very specific. In my opinion Yeray suggested you several options to achieve what you request using existing TeeChart features. Given all those circumstances it's most unlikely that it's implemented in v8. We don't have an estimate date for this being implemented either.
stsl
Post by stsl » Thu Apr 30, 2009 10:57 am
TV52014060 :
Did you use LegendStyle := lsGroups ?
TV52012945 :
For me it's a bug because the function generates wrong values in the graph (0 instead null values).
Best regards
Post by Narcís » Thu Apr 30, 2009 11:38 am
Hi stsl,
V52014060 :
Ok, the problem here is that series groups don't have symbol. So if you want to use symbols there you could use dummy series for that purpose, for example:
var i, j: Integer;
  Chart1.Legend.Visible:=false;
  for i:=0 to Chart1.SeriesCount -1 do
    Chart1[i].ShowInLegend:=false;
  for j:=0 to Chart1.SeriesGroups.Count-1 do
    Chart1.AddSeries(TChartSeries.Create(self));
    Chart1[Chart1.SeriesCount-1].ShowInLegend:=true;
    Chart1[Chart1.SeriesCount-1].Title:=Chart1.SeriesGroups[j].Name;
  ChartTool1.Series:=Chart1[Chart1.SeriesCount-1];
  ChartTool1.Legend.LegendStyle:=lsSeries;
var Flag : TBitmap;
  try
    Dec(R.Top,3);
    Inc(R.Bottom,3);
    Flag.LoadFromFile('C:\root\TeeChartVCL\Sources8\TeeCopy.bmp');
{    if ValueIndex mod 2 = 0 then
      Flag.LoadFromFile('C:\root\TeeChartVCL\Sources8\TeeDepth.bmp');
      // draw border
        Rectangle(R,0);
  finally
stsl
Post by stsl » Thu Apr 30, 2009 12:23 pm
But i need a normal legend with series (not the dummies) and an extra legend with groups (dummies) and check box to disable one or more groups of other series. Is-it possible to do that ? I think that with dummies series it will be complicated.
Why did you disable the OnDrawLegend event when we have lsGroups ? There is no logical reason...
Post by Narcís » Thu Apr 30, 2009 1:47 pm
Hi stsl,
Yes, I'm afraid this would be complicated.
In my opinion the reason it is pretty simple, since series groups don't have symbols for the legend they can't fire the OnDraw event. This is already on the wish-list to be considered for inclusion in future releases.
