Marks values with BubbleChart
Wysu
Post by Wysu » Fri Apr 03, 2009 8:40 am
Im using Tee7 Pro.
I draw a chart containing some bubble series. To avoid that my bubble series crush, I insert them like :
TBubbleSeries(tmpSerie).AddBubble(i, (Bubblemaxvalue*2)*(j+1), myRadiusValue, myName);
(where bubblemaxvalue is the biggest radius value that I have)
then I format my left axis :
Chart.LeftAxis.LabelStyle := talText;
But I found no options in TeeEditSeri to show Radius values in series marks.
smsValue: show Y value
smsLabel : show text
sms XValue : show XValue
smsXY : show X Y values
Is there any tricks ? How can I do ?
Regards.
Post by Yeray » Fri Apr 03, 2009 9:37 am
Hi Wysu,
You could use OnGetMarkText event to customize the series marks:
procedure TForm1.Series1GetMarkText(Sender: TChartSeries;
  ValueIndex: Integer; var MarkText: String);
  MarkText := floattostr(Round((Sender as TBubbleSeries).RadiusValues[ValueIndex]));
I hope this helps.
Wysu
Post by Wysu » Fri Apr 03, 2009 9:54 am
Yeah ! Nice !
Thank you very much.
