MaxPointsPerPage and more problems in v7
Posted: Fri Jun 18, 2004 4:20 pm
I recently upgraded from TeeChart v6 to v7. The main reason to upgrade was that I hoped that a number of bugs in v6 would be fixed in v7. I am very disappointed to see that these bugs have not been fixed; moreover, some new limitations have been introduced in this version. My problems are the following:
1) MaxPointsPerPage = 1 still doesn't work. I discussed this months ago with the support staff and they suggested it would be fixed in v7.
2) In v6, I used my own scrollbar to scroll the legend when it became too large. I tried switching over to the new LegendScrollBar. To my surprise, when MaxPointsPerPage is used, the legendscrollbar then scrolls the pages instead of the legend items. With my own code it is impossible to scroll the legend items in v7 when paging is used. In v6 this was possible.
3) When using PrintPartialCanvas to print to a metafile, if the PrinterRect parameter's Left and Top properties are not 0, the chart does not draw correctly to the metafile; instead it comes up all squashed. This happened in v6 and still happens in v7. I never reported this problem.
4) When zoomed in on a line chart, a TMarksTipTool will not provide a tooltip on the line on that part of the line before in the area before the first value on the x-axis. I never reported this problem either.
5) Not so much a problem of mine, but it doesn't look too good: the version resouces of all the v7 bpl's state that they are TeeChart v5.0.
I am now planning to revert back to version 6 as this at least makes point 2) work.
Robert Croshere
Robert Croshere
