Bug in THistogramSeries
xray
Post by xray » Tue Mar 03, 2009 12:22 pm
Dear TChart Team,
I have found a bug in Version 8.04. The display/bottom axes of THistogramSeries is obviously wrong. The data is displaced on the x-axis.
To reproduce this: Add a HistogramSeries to a Chart. Then fill the HistogramSeries using this code:
i: Integer;
Pos: Double;
HistogramSeries.BeginUpdate;
try
Pos := -1;
HistogramSeries.Clear;
for i := 0 to 100 do
if (Pos > 0.5) and (Pos < 0.7) then
HistogramSeries.AddXY(Pos, 50, '', clRed)
HistogramSeries.AddXY(Pos, 0, '', clRed);
Pos := Pos + 0.05;
finally
HistogramSeries.EndUpdate;
HistogramSeries.Active := True;
Chart.Repaint;
Then you will see that the maximum is displayed arround one (1) on the X-axis and not arround 0.6.
This worked previously using version 7.x
best regards,
Post by Yeray » Tue Mar 03, 2009 4:18 pm
Hi xray,
We've tested your code, reproduced the problem with the 8.04 installation and solved it. So this is solved for the next maintenance release.
As you are a source code customer, we will give you a link to download the actual sources as soon as possible.
mbruch
Same Problem!
Post by mbruch » Wed Mar 04, 2009 6:48 pm
I am a source code customer,
Please send me the patch!
Best Regards
Michael
Post by Narcís » Thu Mar 05, 2009 10:25 am
Hi Michael,
Sure, just sent current sources.
mbruch
Post by mbruch » Sat Mar 14, 2009 8:15 pm
after some zooming test the bug appeared!
If you zoom the content the x axis is mixed with some data points.
samples:
Post by Yeray » Mon Mar 16, 2009 9:39 am
Hi Michael,
Please, could you send us a simple example project we can run "as-is" to reproduce the problem here?
sIT
same problem
Post by sIT » Mon Mar 16, 2009 1:40 pm
9348257 wrote:Hi xray,
I have the same problem.
Please send me the link to the source code too.
Thank You.
I have a second problem.
When I call EditChart with a Histogram Series and click on the series then the property Series.General.Depth.Auto will automatically deativated!
Gerhard
Post by Yeray » Mon Mar 16, 2009 4:37 pm
Hi Gerhard,
I've sent you a mail with the link to download the VCL sources.
Regarding the other Histogram issue, I'm not sure to understand what are you exactly trying to achieve. Could you please send us a simple example project we can run "as-is" to reproduce the problem here?
sIT
Post by sIT » Tue Mar 17, 2009 6:30 am
9348257 wrote:Hi Gerhard,
I upload an example program where you can reproduce the error.
I'm using Delphi 2009 for compiling.
Click on Edit -> Series1.
Result: The General Auto Property will be disabled!
Post by Yeray » Tue Mar 17, 2009 8:39 am
Hi Gerhard,
I'm afraid that I'm not able to reproduce your problem with TeeChart v8.04 neither with actual sources. Are you still suffering this with the sources I sent to you yesterday?
Note that we recommend you to use TeeRecompile Tool to install the sources, but even if you used it, could you please verify your IDE's search path and library path?
sIT
Post by sIT » Tue Mar 17, 2009 10:34 am
I checked all pathes and the complete installation. There is all Ok. I compiled the sources with TeeRecompile.
But what I find is that I'm not able to change the Depth property in THistogramSeries. When I change this property during design time the Depth will not be store in the dfm file!
With TLineSeries all is working well.
Post by Yeray » Tue Mar 17, 2009 11:04 am
Hi Gerhard,
Now I understood and could reproduce the problem. So I've added it to the wish list to be fixed in future releases (TV52013974).
mbruch
X scale error
Post by mbruch » Wed Mar 18, 2009 11:55 am
Did you look at my uploaded project?
Post by Yeray » Wed Mar 18, 2009 3:37 pm
Hi mbruch,
Excuse us, we haven't noticed that you sent a project.
Now, I've seen it and your problem seems different than the discussed in this thread.
The problem here is that you have two series populated with different interval X values and the same X axis assigned. Then, when axis labels try to be shown automatically, there causes some conflict.
First of all I think you should have present what series labels you want to show (and place it at the top of the series list), and then prepare you series and your bottom axis to show the labels correctly. Here there are some properties that may help you in this:
	chrtDruck->Axes->Bottom->LabelStyle=talValue;
	chrtDruck->Axes->Bottom->DateTimeFormat="dd/mm/yyyy hh:mm";
	chrtDruck->Axes->Bottom->LabelsSeparation=15;
	chrtDruck->Series[0]->XValues->DateTime=true;
	chrtDruck->Axes->Bottom->Increment=DateTimeStep[dtOneDay];
mbruch
Post by mbruch » Wed Mar 18, 2009 4:43 pm
in Version 4 all worked fine!
All series have datetime as xaxis all the same.
on one series I set a label information and style is label not legend!
Please check
>> ok if I use your supplied code it works!
Best Regards
Michael
