Pie Series Options tab is blank in the editor
jls
Post by jls » Tue Feb 24, 2009 10:07 am
I used the Tee8New.exe demo
Go to Pie series
Edit
The options tab is blank
Also happen if you
1)Change to Group Slices
2)Select General
3)Go back to Series1
Any solution?
Jørgen
Post by Yeray » Tue Feb 24, 2009 11:12 am
Hi Jørgen,
I couldn't reproduce the problem here. Do you mean the demo at All Features/Chart Styles/Pie?
What TeeChart version are you using? Could you please verify that you are using the latest version available at the client area?
Can you reproduce the problem in a simple new project? If you can reproduce it in a new simple project, probably you have wrong or confusing search and library paths.
jls
Post by jls » Thu Feb 26, 2009 9:20 am
Uploaded sample steema.public.attachments
I use TChart Pro V 8.04
Delhi 2007
Click on Edit
Select Series 1
Jørgen
Post by Yeray » Thu Feb 26, 2009 3:58 pm
Hi Jørgen,
Now I could reproduce the problem and I've added it to the wish list to be fixed as soon as possible (TV52013899).
It seems that this problem only happens for pie series and the editor's tree mode.
