V8.04 out of system resources
ahab
Post by ahab » Tue Feb 10, 2009 9:05 am
I just switched to V8.04 and after about 5 calls to show a teechart, I get a message that system resources are exhausted. This did not happen with V7.07. Why?
Post by Yeray » Tue Feb 10, 2009 10:02 am
Hi ahab,
I'm not sure to understand you. Do you mean that you are creating several charts without destroying them? Note that if you don't need a previous chart, delphi won't destroy it for you. You have to call:
Chart1.Free;
If you mean something different, please, could you send us a simple example project we can run "as-is" to reproduce the problem here?
ahab
Post by ahab » Sun Mar 01, 2009 4:09 am
The zip file teetest shows the problem. In an attempt to thicken the plot lines, I tried using borders or outlines. This causes the "out of system resources".
Post by Yeray » Mon Mar 02, 2009 12:00 pm
Hi ahab,
I can reproduce your problem when I execute your application but after recompiling it, it seems to work fine. So that makes me think that you could have some old TeeChart paths in your IDE's search and/or library paths. Could you verify these lists and remove the remaining references to the old TeeChart paths if the are still present?
