Error on deleting a shape polygone in TMapSeries
odissey1
Post by odissey1 » Sat Dec 06, 2008 10:55 pm
I am trying to delete a Shape in TMapSeries in code like (either one)
SeriesMap.Shapes.Free;
SeriesMap.Shapes.Polygon.Free;
which returns Error in runtime.
Manual deleting (select+delete kbd button) gives error in Tee8new either.
Is there any way to delete a certain shape in TMapSeries
(like SeriesMap.Delete)?
regards,
odissey1
Post by Narcís » Tue Dec 09, 2008 11:40 am
Hi odissey1,
Yes, you can use Delete method, for example:
  Series1.Delete(0);
Or deleting all polygons:
  for i := Series1.Count-1 downto 0 do
    Series1.Delete(i);
Which is the equivalent of this:
  Series1.Clear;
odissey1
Post by odissey1 » Tue Dec 09, 2008 7:02 pm
narcis wrote:Hi odissey1,
  Series1.Delete(0);
-I am afraid not. At least not in my TeeChart v.7.12. Compiler say: 'There is no overload version of Series1.Delete(0)';
But something wrong in TeeChart 8.x also. Try to open Tee8new.exe -> MapGIS series -> Edit -> Shapes. Now select any shape with a mouse. Hit 'Delete' button on keyboard. You will get an error message.
odissey1
Post by odissey1 » Tue Dec 09, 2008 7:35 pm
I posted a screenshot on Attachments forum
Post by Narcís » Wed Dec 10, 2008 9:11 am
Hi odissey1,
This works fine for me here using v8.04
I could reproduce this and added the issue to the defect list (TV52013644) to be investigated.
sicorspa
Post by sicorspa » Tue Feb 03, 2009 3:33 pm
don't know if it's correct but this also works like delete i think
Series1.Shapes.Points.Delete(0,Series1.Shapes.Points.Count - 1,False);
am I right? :?
Post by Pep » Mon Feb 09, 2009 12:07 pm
It's strange, I've just checked the latest TeeChart Pro VCL v7 sources and you should be able to use the Delete method, it exists since the earlier versions. You could check if TeeChart is correctly installed.
am I right? Confused
The Series.Delete(x) method deletes a specific shape from Map Series, and the method you're using Series.Shapes[x].Delete(start,end,removegaps) would remove all points from shape but wont remove (free) the shape created. it will remain there as a data point. The correct method to remove completely a specific shape is the Delete(x).
sicorspa
Post by sicorspa » Mon Feb 09, 2009 12:33 pm
many thanks, I'm just using delete(x) but before tried the points.delete.
Howether thanks because it's always better to know the exact function of a procedure/function :wink:
