Marius
- Newbie
Post
by Marius » Tue Oct 28, 2008 6:45 pm
I get an invalid pointer operation when using a Bollinger band in my chart. I've been able to reproduce it by creating a new application and dropping an empty TCHart on it. Then in FormCreate I add the following
Line : TLineSeries;
Bollinger1 : TLineSeries;
Line := TLineSeries.Create(Chart1);
Line.FillSampleValues(100);
Bollinger1 := TLineSeries.Create(Chart1);
Bollinger1.SetFunction(TBollingerFunction.Create(Chart1));
Bollinger1.DataSources.Clear;
Bollinger1.DataSources.Add(Line);
Chart1.AddSeries(Line);
Chart1.AddSeries(Bollinger1);
Run the app. It displays fine but when I close the app it throws the exception.
Can someone please verify that my code is correct..
BRgds,
Marius
Marius
- Newbie
Post
by Marius » Thu Oct 30, 2008 9:41 am
Why am I not getting any replies?
Is this not the place to go for support on TChart?
Post
by Narcís » Thu Oct 30, 2008 10:18 am
Hi Marius,
Yes, this is the place to receive support with TeeChart. We didn't reply earlier because, as you can see in
our public holidays calendar, yesterday was a local holiday.
Regarding your technical inquiry, we have been able to reproduce the issue here. We found that doing the same using the chart editor works fine. We will need some time to investigate which is the problem here and will get back to you when we have further news.
Marius
- Newbie
Post
by Marius » Thu Oct 30, 2008 10:21 am
Thanks Narcís
Didn't realise there was a holiday
Awaiting your reply on the main issue following your investigation
BRgds,
Marius
Post
by Pep » Mon Nov 03, 2008 11:42 am
Hello Marius,
basically, the problem is the lines order. Using the same code, but changing a little bit the order should work fine :
Line : TLineSeries;
