TChart installation, yet again
kmanuele
Post by kmanuele » Tue May 25, 2004 4:17 am
Doing a manual compile in BCB5, one project at a time (the project group simply does not work) -- the following order:
Tee6C5
TeeUI6C5
skip TeeDB6C5, because I don't want the DB components
DclTee6C5, doesn't work, wants TeeDB6C5
Redo TeeCB6C5 and DclTee6C5, ok
TeePro6C5
TeeLanguage6C5
DclTeePro6C5, fails, can't find ColnEdit.dcu
TeeGL6C5, warning: Constructing instance of TGLCanvas containing abstract methods
DclTGL6C5, same warning as above
skip TeeQR6C5, don't want quick report stuff
skip DclTQR6C5
TeeImage6C5
go back and try DclTeePro6C5, still wants ColnEdit.dcu
Almost made it this time !!
Where and what is ColnEdit.dcu?? It is not in the TChart source code.
Help, yet again
Kevin
Post by Pep » Wed May 26, 2004 9:05 am
Hi kevin,
please see the solution to this problem at the folloiwng link :
http://www.teechart.net/support/modules ... cppbuilder
If you still having problems you can try to use the TeeRecompile tool (available for download on our web site , at the private customers download page) which Recompiles/Installs the packages.
