Special-Zoom with Custom Axis
Woehr.Mi
Post by Woehr.Mi » Mon Aug 18, 2008 12:07 pm
I have up to 8 Custom Axis on the left side in my TeeChart:
Custom Axis 1 | . . . . . . . . .
Custom Axis 2 | . . . . . . . . . . .
Custom Axis 3 |__________________
.. ... BottonAxis (Time)
and so on...
And I have to handle the Zoom-Feature of the Chart in a way, that only the CustomAxis which are in the Zoom-Rectangle are visible to get a better division of my different Series (that I have no area which is empty). But at the moment I have no idea how the get the information which Custom-Axis (Index of the CustomAxis) are in the Zoom-Rectangle. javascript:emoticon(':?:')
Question
Thanks for your answers
Michael
Post by Yeray » Tue Aug 19, 2008 11:55 am
Hi Michael,
If we understand well what you are trying to do, the following code could be a good example of how you could achieve it with two series (one vertical custom axis). We will hide everything out from the pointer when the mouse is unpressed. And we restore the "default view" when unzoom.
  StartX := X;
var i, j: Integer;
  Caption := 'Y: ' + IntToStr(Y);
  if (StartX < X) then
    for i := 0 to Chart1.Axes.Count -1 do
      if not ((chart1.Axes.Items[i].Horizontal) or (chart1.Axes.Items[i].IsDepthAxis)) and not (Chart1.Axes.Items[i].OtherSide) then
        if (y > Chart1.Axes.Items[i].IStartPos) and (y < Chart1.Axes.Items[i].IEndPos) then
          chart1.Axes.Items[i].StartPosition :=0;
          Chart1.Axes.Items[i].EndPosition := 100;
          for j := 0 to Chart1.Axes.Count -1 do
            if not ((chart1.Axes.Items[i].Horizontal) or (chart1.Axes.Items[i].IsDepthAxis)) then
              chart1.Axes.Items[j].Visible := false;
          chart1.Axes.Items[i].Visible := true;
  end
    chart1.Axes.Items[2].StartPosition := 0;
    chart1.Axes.Items[2].EndPosition := 50;
    chart1.Axes.Items[6].StartPosition := 50;
    chart1.Axes.Items[6].EndPosition := 100;
  for i := 0 to Chart1.SeriesCount - 1 do
    Chart1[i].Visible := Chart1[i].GetVertAxis.Visible;
