What happened to MinVisibleValue & MaxVisibleValue
Phineas
Post by Phineas » Tue Aug 05, 2008 10:55 pm
I have searched everywhere, through the source code, through the examples. Where is:
MinVisibleSeriesValue
MaxVisibleSeriesValue
MinVisibleValue
MaxVisibleValue
I'm trying to get my left axis to scale correctly while scrolling.
Delphi6
TChart 8 VCL
Post by Yeray » Wed Aug 06, 2008 8:37 am
Hi Phineas,
The methods you mention are exclusive ActiveX methods. Here is how you could calculate the same in Delphi.
And please, let us know if we've mistakenly documented the methods you mention as belonging to the VCL version, and if so, where we can find the error to correct it.
function TForm1.MaxMinVisibleValue(IsMax:WordBool;AllSeries: WordBool; SeriesIndex: Integer; FAxis: TChartAxis): Double;
Var i,j,firstSeries,startSeries,endSeries : Integer;
    tmpResult,tmpVal : Double;
    firstTime: Boolean;
  firstSeries:=-1;
  firstTime:=True;
  tmpResult:=0;
  With FAxis.ParentChart do
  Begin
    If AllSeries=True then
    Begin
      for i:=0 to SeriesCount-1 do
      Begin
        if (Series[i].Active) then
        Begin
          firstSeries:=i;
          break;
    end
      firstSeries:=SeriesIndex;
    if (firstSeries>=0) and (firstSeries<SeriesCount) then
    Begin
      Begin
        startSeries:=0;
        endSeries:=SeriesCount-1;
      end
      Begin
        startSeries:=SeriesIndex;
        endSeries:=SeriesIndex;
      for i:=startSeries to endSeries do
      Begin
        if ((Series[i].AssociatedToAxis(FAxis)=True) and (Series[i].Active))then
          for j:=Series[i].FirstValueIndex to Series[i].LastValueIndex do
          Begin
             if FAxis.Horizontal=True then
               tmpVal:=Series[i].XValue[j]
               if (Series[i].YValue[j] <= FAxis.Maximum) and (Series[i].YValue[j] >= FAxis.Minimum) then
                 tmpVal:=Series[i].YValue[j];
             if firstTime then
             Begin
               tmpResult := tmpVal;
               firstTime:=False;
             end
             Begin
               if (IsMax) then
               Begin
                 if (tmpVal>tmpResult) then
                    tmpResult:=tmpVal;
               end
               Begin
                 if (tmpVal<tmpResult) then
                    tmpResult:=tmpVal;
          end
    end
  result:=tmpResult;
Phineas
Post by Phineas » Wed Aug 06, 2008 9:08 pm
Thanks for that Yeray
Now how to use it.
Would this be the call to the function?
Chart1.LeftAxis.SetMinMax(MaxMinVisibleValue(false, true, 0, Chart1.LeftAxis), MaxMinVisibleValue(true, true, 0, Chart1.LeftAxis));
And where to place it.
OnAddSeries
OnAfterDraw
OnBeforeDrawSeries
OnBeforeDrawAxes
OnScroll
I placed a tChart on a form.
Series1 := TLineSeries.Create(Chart1);
Series1.FillSampleValues(3000);
Chart1.AddSeries(Series1);
Chart1.BottomAxis.SetMinMax(1,10);
ChartScrollBar1.RecalcPosition;
procedure TForm1.Chart1BeforeDrawSeries(Sender: TObject);
I have had nothing but crashes trying to get it to work and/or series1 just disappears. I get worse results when Series1 is TCandleSeries.style := csCandleStick;
What am I doing wrong Yeray?
Post by Yeray » Thu Aug 07, 2008 8:14 am
Hi Phineas,
Some considerations:
1) I've fixed the function I told you yesterday modifying one line of code. Where said:
if (Series[i].YValue[j] < FAxis.Maximum) and (Series[i].YValue[j] > FAxis.Minimum) then
Now it's:
2) I recommend you to use Chart1.Axes.Left or Chart1.Axes.Bottom instead of Chart1.LeftAxis or Chart1.BottomAxis because they are deprecated properties.
3) You probably get this error because you are calling the function in OnBeforeDrawSeries event. Note that in the function you are reading the series' values, so you cannot call this function until teechart has the series' values calculated.
So here I recommend you to use another event as OnAfterDraw or OnScroll.
