yam49
- Newbie
Post
by yam49 » Fri Jul 25, 2008 7:42 am
I'm compiled Tee8QR4D2007.dpk and DCLTEE8QR4D2007.dpk for using TqrChart composant.
When i make installation, it's OK, but when i want to use the composant, i have a error message
When i go to the "package installer" of delphi and i show the "teechart for quickreport" package, it is empty
Thanks for your help and all my excuses for my bad english
[/img]
Post
by Yeray » Mon Jul 28, 2008 8:50 am
Hi yam49,
Could you try to follow the QuickReport instructions
here?
And note that in this topic title you talk about QuickReport v5 and the packages you are mentioning are from QuickReport v4 (xxxQR4xxx.dpk and DclxxxQR4xxx.dpk).
yam49
- Newbie
Post
by yam49 » Mon Jul 28, 2008 10:31 am
I have purchased the QR5 Pro, and Teechart 8.02, When i have installed teechart, i don't have any file xxxQR5xxx.dpk but only xxxQR4xxx.dpk
I have make the compilation with this file, i just modify in the package the uses Qr4rund11.cpp in Qr5rund2007.dcp
With this modification, i can compiled the package and installed it
cordially
Post
by Yeray » Tue Jul 29, 2008 7:32 am
Hi yam49,
I'm happy to see that!
yam49
- Newbie
Post
by yam49 » Tue Jul 29, 2008 8:13 am
Sorry, but I am badly expressed.
In the previous pos, i explain the method that I used to install the component, which appears but disappears as soon as I try to use it, as indicated in my firt message.
The problem is not solved and I have no solution, the topic precedent would seek to explain why I use the file xxxQr4xxx and my post speaks of QR5
Please help me because I turn in circles to do nothing
best regards
Post
by Yeray » Tue Jul 29, 2008 8:37 am
Hi yam49,
I've sent a link to download the v8.03 Release Candidate to your email account. As you are source code customer, probably the easiest way to install everything may be using TeeRecompile.
yam49
- Newbie
Post
by yam49 » Wed Jul 30, 2008 8:06 am
Good morning,
I installed the TeeChartPro8.03 from source and launched the compilation and installation with teerecompile (i have check the quickreport box). It installs teechart, but I have always an error message on the launch of Delphi and to be able to execute delphi, I must delete the file, as a result I did not always component TQRCHART
If you have another idea
Best regards
Post
by Narcís » Wed Jul 30, 2008 8:08 am
Hi yam49,
Which is the exact error message you get when launching Delphi?
yam49
- Newbie
Post
by yam49 » Wed Jul 30, 2008 9:38 am
This message
Cordially
yam49
- Newbie
Post
by yam49 » Wed Jul 30, 2008 9:46 am
When i put in the dephi/bin directory the 4 files find in the TeeChart/bin compiled directory
I have a new error message
if I did not remove that reference, I can't use delphi
Post
by Narcís » Wed Jul 30, 2008 9:58 am
Hi yam69,
Thanks for the information. In that case your problem seems the same as discussed
here.
Hope this helps!
yam49
- Newbie
Post
by yam49 » Wed Jul 30, 2008 1:34 pm
That's it works !
Once re-made sources, we must open the project TEE8QR5D11.dpk and replace the file TEE811.DCP by TEEPRO811.DCP, compile and copy the file TEE8QR5D11.BPL instead of the one made by the installation procedure. (normally in windows\system32)
Then open the project DCLTEE8QR4D11.dpk and replace DCLTEE811.dcp file by file DCLTEEPRO811.dcp, then compile and replace the file DCLTeePro811.dcp (normallly in tne compiled bin directory of Teechart)
Thanks to all
Post
by Narcís » Wed Jul 30, 2008 1:38 pm
Hi yam49,
You're very welcome! I'm glad to hear you could solve the problem
