Event line in a TBarSeries
TestAlways
Post by TestAlways » Tue Jul 08, 2008 12:47 am
I need to add an event line below a TBarSeries, showing events. The user can then see where events occur in the series.
Something like the red line with orange triangles shown in the image below:
(I don't really want to overwrite the axis title--I just wanted to mock something up).
How would I accomplish something like this using TChart?
Thank you,
Ed Dressel[/img]
Post by Yeray » Tue Jul 08, 2008 8:16 am
Hi TestAlways,
I've achieved something really similar to your picture with the following code. In this example, Series1 is the BarSeries and Series2 is a LineSeries.
var max: double;
  Chart1.View3D := False;
  Series1.FillSampleValues(15);
  Chart1.MarginBottom := 7;
  Chart1.Axes.Left.AutomaticMinimum := False;
  Chart1.ClipPoints := False;
  max := Series1.YValues.MaxValue;
  Series2.Pointer.Visible := True;
  Series2.Pointer.Size := 7;
  Series2.ShowInLegend := False;
  with Series2 do
    AddXY(0, -max/10);
    AddXY(7, -max/10);
    AddXY(9, -max/10);
    AddXY(10, -max/10);
    AddXY(14, -max/10);
function TForm1.Series2GetPointerStyle(Sender: TChartSeries;
  ValueIndex: Integer): TSeriesPointerStyle;
  if Sender = Series2 then
    if (ValueIndex = 0) or (ValueIndex = Series2.Count-1) then
      Result := psNothing
      Result := psTriangle;
TestAlways
Post by TestAlways » Tue Jul 08, 2008 4:48 pm
Nice work! As far as I can tell (until implementation) it's going to be exactly what I need.
But one question, on a series click, how do I get the X index (not the X value)?
Post by Yeray » Wed Jul 09, 2008 7:53 am
Hi Ed,
As you can see in the method header, you have the ValueIndex.
procedure Series1Click(Sender: TChartSeries; ValueIndex: Integer;
      Button: TMouseButton; Shift: TShiftState; X, Y: Integer);
